Light help
Old Jul 23, 2015 | 01:11 PM
alstang1's Avatar
alstang1
Light help
I have a jet ski flat plug and a 5th W round plug. Both, when connected, have break, hazard and turning lights but no running lights. Is there a separate fuse for running? What can I check? I have ensured good connection multiple times on both.
Old Jul 24, 2015 | 02:46 PM
IDMooseMan's Avatar
IDMooseMan
I'm assuming you mean you have a 4-way plug you use when towing your jet ski, and a 6-way or 7-way for your fiver. I have a PDF that might help determine whether your wiring setup is correct or not. Hope it helps.
Well, shoot. I can't attach files. If you want, I can email it too you, or try to PM you the PDF document.
I have a 7-way setup and use a U-Haul 4-way adapter when I rent their trailers. I have no problems using the 4-way adapter in my 7-way setup.
Edit:
Nope, I can't attach files in the PM system either. Email would be the only way to get it to you.
Old Jul 24, 2015 | 04:50 PM
Carlene's Avatar
Carlene
Admom
ID, how were you trying to upload the PDF?
If you go to Advanced Posting, scroll down to "Additional Options" then "Manage Attachments" you should be able to upload any PDF as long as its small than 4.77mb.
Test:
File Type: pdf
Old Jul 24, 2015 | 06:10 PM
IDMooseMan's Avatar
IDMooseMan
My "Posting Rules" at the bottom of the page states, "You may not post attachments." The options you mentioned are not visible to me.
Old Jul 24, 2015 | 07:11 PM
Carlene's Avatar
Carlene
Admom
I guess you have to be a club member to post attachments soooooooo, try it now.
Thanks for helping.
Old Jul 24, 2015 | 07:45 PM
IDMooseMan's Avatar
IDMooseMan
Thank you for adding me to the Club, Carlene. I can see it now, so...there should be a PDF attached to this post.
I'm glad I could help.
File Type: pdf
Old Jul 24, 2015 | 07:57 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Down in the "OTHER" section of this forum you will find the "READ FIRST" and Towing Tips where you will find the wiring diagrams. https://www.ford-trucks.com/forums/5...6-11-12-a.html
Old Jul 24, 2015 | 08:25 PM
IDMooseMan's Avatar
IDMooseMan
Thanks for that link, Bud. Tried to send Reps, but the system says I gotta spread the love some more. I have that thread bookmarked now.
Pavin2
Dec 3, 2017 06:58 PM
lbrauer
Feb 10, 2016 02:33 AM
ZEALOUS_DRAGON
Jul 2, 2015 09:53 AM
jonney_boy
1997 - 2003 F150
Nov 20, 2005 05:42 PM
