Rebuilding the 460
It's got a 460 w/650 holley, BW T-18, & Dana 60 w/ 3.73 gears
Block-(D1VE-6015-A2B) heads-(D3VE-A2A) Intake-(D6VE-8425-A3A)
I want to get at least 600hp out of the engine when I'm done.
I'm just having a hard time coming up with a good combination of parts. I found the cam I want was too extreme for my stock heads (Could this be taken care of with head work?), and wouldn't work well with a tunnel ram...Do I want a tunnel ram on a set up like this? What would be the best intake?
Also I don't know if I could get the heads worked over enough to handle that kind of HP or do I need to get new ones? I don't want Aluminum
I'm building this strictly for dragracing
I want to build the compression to at least 10.5 to 1
Bore it out (But not sure how much is safe)
Where would be some good places to find dependable parts for this?
I've got the Ignition system figured out..I think...
I'm going with a complete MSD setup.
The Pro Billet dist.
Blaster 2 coil
and the 6AL box with a three step module selector
As far as the air intake I want to get ahold of the K&N 14" with the breathable top...the bottom will sit just about flush with the top of the hood (hopefully)
I'm also getting the 1 piece F/G GT500 style front end that rolls foward. But the body's not important at this point....
If anyone has some good suggestions on what will get me into my HP goal please feel free to enlighten me!! I'm still kinda new to the "Old car" thing....
Thanks
Darrell
I don't think you will want a tunnel ram. No need for that. Heck you can make 600 hp with a dual plane Stealth and still have tons of torque.
BTW, what cam were you wanting to run?
JJ
The reason I'd like to stay away from aluminum: I dunno, I've heard the aluminum heads warp quickly and easier, just don't last as long...
Which would be the better of the two between the C9VE or D0VE?
I do want to get oversized valves, but I don't know how big yet....
How big can you safely bore these out? I've heard people taking about boring it to a 504 up to a 514 but I think that sounds a little extreme?? I dunno
Most 514's that you hear of are actually stock bore. They have been stroke to 4.3 inches from the 3.85 stock. That stroke with 0.030 overbore gives a 521 which is also common.
I don't think aluminum heads are less durable. But nobody is making you use them. Anyway, let us know on the cam if you get a chance.
JJ
I found a set of alum. CobraJet heads for the 460 with oversized valves (2.200" intake, 1.76" exaust) and springs, but I don't really like the price...they're proud of those things
The original cam I was looking at is a Comp cam. Magnum cam. PT#249-CL34-331-4
280* adv. dur., 530" lift, RPM range 2000-6000
I'm also looking at a Lunati cam PT#638-41605
300/310 adv. dur., 559/572" gross lift 3000-6500rpm
Lunati also has another PT#638-41607
305/314* adv. dur., 603/609 gross lift 4000-7400RPM
Those cams you are talking about, those don't look like roller specs, at least not the lift. I think you'd be much happier with a roller. When you're trying to get that much hp, a roller is a much better choice. More aggressive ramps allow the overall duration to be less which gives you a much milder mannered motor but still more hp/torque when you need it.
JJ
I think those cams were rocker style....
So rollers are better? Where can I find a good "kit" with the springs, lifters, cam, and chain?
All the cams I have found so far are rockers
What do you think would be an ideal dur. and lift?
And I'm also not sure about the RPM ranges...I do know that mine raps real tight at 4500rpm. Will a new cam make it rap higher, or just faster? did that make sense?
Rockers on the other hand are the fulcrums which translate lifters going up and down on the cam into valves opening and closing. They rock back and forth on their pedestal. They come in different varieties as well. Most stock rockers are just stamped steel. They have no bearing, they just slide on a fulcrum more like a bushing. Higher end rockers have roller tips, where the end of the rocker has a roller that rolls on top of the valve which reduces friction. Even higher end rockers are aluminum or forged steel and have roller bearings at the fulcrum and a roller at the tip. These substantially reduce friction.
If you get a new cam like the ones mentioned above the engine's power will be made around 2500-6000 RPM's. The reason your engine feels like it is rapped out at such a low RPM is probably two fold. First it's probably not balanced very well. They don't take the time from the factory to do a great job at that. And for the most part it doesn't matter that much at lower RPM's. Second, your engine combo is actually running out of power at those higher RPM's. An engine doesn't necessarily make more power at higher RPM's. The combination of components making up that engine determine it's best operating range. The effects of friction combined with the fact that the heads/cam etc are not allowing enough air in for your engine to turn more RPM's limits your engine's effective RPM range. After a certain RPM any engine will actually start to make less power. Those new cams, if matched to other components properly will make the most power in the range of 2500-6000 RPM's. Since your engine will also be making more hp it will also allow it to rev up quicker, especially under a load, i.e. accelerating while in the truck. I hope this helps.
JJ
BTW there are several books available that talk about engine basics as well as camshaft basics. You might want to check those out, too.
I do have alot of learning about this before it acually goes together....
Do you have any titles to specific books? I'm gonna try to make it to a bookstore this weekend...
Again..thaks for your help, and input!!
You sound like you know a lil' somethin bout these things? Wanna build mine, or at least have a hand in it
I appreciate your quick responses...
darrell
JJ
I'm lookin' for a second job as we speak...Just trying to get er' done faster..
Thanks for all the help! I'm sure I will be asking more from you!!
