manual trans shifting problem
Here's the first big clue. When I shifted back into 5th, the gear shifter went into gear with no problem, but the clutch would not re-engage despite the pedal returning to its normal position.
Here's the second clue. Since I couldn't get the clutch to re-engage I decided to try one more data-gathering action. I turned the engine off (still coasting at 70 mph) and tried to restart. It would not restart, exactly as if I had not depressed the clutch pedal. So, I coasted for as long as I could and then walked the remaining 1.5 miles for help. (Silly me left my phone at home.)
Here's the third clue. When I got back to my car about an hour later I tried to start it again. No joy, but then I heard a click underneath the car when I released the clutch pedal. I tried once again and it started. I drove the remaining 1.5 miles to the exit and started to notice the clutch appearing to stick for a second and then suddenly release. When I got to the gas station where I was before, it was done, just like on the freeway. Again, the gear shifter and the clutch pedal operated totally fine, but it seemed that the business end of the clutch would not re-engage until it cooled off. After it cools off, everything seems to work just fine.
So:
1999 Explorer Sport
4L V6 SOHV
5-speed manual
196,000 miles
Any ideas? What should I check?
I had this happen a couple times on my '91 Ranger when going over the mountain passes when it was hot. I attributed this to water in the clutch (brake) fluid in the clutch reservoir. Brake fluid likes to absorb water and that lowers the boiling point. The only difference with mine was that I could not shift out of 4th gear after getting to the top of the pass. I didn't try real hard and I didn't try to shift without the clutch. A mile or two of cruising on level ground allowed it to cool off enough so that I could shift back into 5th gear. On the same trip, it happened again on the next pass. On the way back, I turned the heater on high and that was enough to prevent the problem (or maybe it was just coincidence).
First thing I would do is check the reservoir level. After that, I would consider flushing the clutch system. It's probably the only fluid in your Explorer that hasn't been changed. Be careful. If you get air in the clutch, it can be very difficult to bleed.
