WWYD 1957 F100
Old 07-26-2015, 10:10 AM
BigMasterCheese's Avatar
BigMasterCheese
BigMasterCheese is offline
WWYD 1957 F100
Originally Posted by Christopher Paul
I am having the exact question about my 57' ford pickup. i will probably start with removing the front qtr panels for more room than messing with brakes, suspension and everything from there, who knows. my first project/
I think I am going to just go through the mechanics to insure everything is as it should and then just work on interior. It is rust free so I probably will jut let the paint go for now. I want to be able to drive it without the fear of messing something up, for now anyways.
Old 07-26-2015, 10:14 AM
BigMasterCheese
WWYD 1957 F100
Originally Posted by Walston
#3 I want to bring the back end down as well. What is the less expensive and invasive method you would recommend?
I agree that the front is either too low or the back is too high. I have not done this, but I have rear that you could mount the rear end on top the leaf springs instead of below it, Seems to me that that would lower it quite a bit. Another less drastic option is to remove some leaves, that is as long as you are not gonna haul heavy stuff.
Sorry about what happened with your truck, that defintaly not a good end to the day. Thanks for the info. No, I will not be hauling anything so I may try removing a leaf or two? Does it matter which ones or is just trial and error?
Old 07-26-2015, 11:28 AM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
BMC Here is a shot of the seat. It tucks in nicely below the window giving me all the leg room possible. One of these days when I can stop driving it I will have it reupholstered.
Here they are (I'm easily distracted)
Old 07-26-2015, 12:58 PM
Walston's Avatar
Walston
Walston is offline
Pic's missing Wally.
Old 07-26-2015, 12:59 PM
Walston's Avatar
Walston
Walston is offline
Remove the shortest ones first. Maybe start with taking out two.
Old 07-29-2015, 02:12 PM
twitbeck's Avatar
twitbeck
twitbeck is offline
you can take the main spring off and reverse the eyes. that means bend it the opposite way and mount it upside down. find how to's on Youtube. You may have to reverse one of the mounts also. Cant remember.
Old 07-29-2015, 03:49 PM
BigMasterCheese
That does work great, and looks good!
Old 07-29-2015, 03:54 PM
BigMasterCheese
I just had to share what the first video I ran across was...
wtf
Old 07-29-2015, 06:00 PM
theodore/teddy
Refyred
Well there is 2:39 I will never see again!
Old 09-17-2015, 02:34 PM
BigMasterCheese
Quick update Not being able to keep it running I took off the fuel pump and it was all gummed up. So it was easy to find where I needed to start. New fuel pump, take out gas tank to get cleaned, as well as the radiator. I learned the hard way that the tank actually had a drain. (guessing that served a purpose when fuel was not as stable?) Anyhow, need to replace radiator hoses and was checking thermostat...which there was none. As well as the hole for the bolt of the thermostat housing being half gone. Any idea what thermostat I would need and how I would find a replacement part for the housing? May be a newbie question...but that is me, a newbie. Again it is a 352.. that is about all I know. Thanks.
Old 09-20-2015, 09:24 AM
manglass's Avatar
manglass
manglass is offline
Rock Auto has the thermostat and gasket. Just look it up as a 1961 Galaxie. The usual repro sellers seem to carry the housing. A quick google search of "Ford FE thermostat housing" yielded C&G Ford Parts, CJ Pony Parts, and Scott Drake with possibilities. Check photos before ordering to make sure the hose end is about the same size, shape, and direction as yours. The intake manifold end is the same on all.
Old 09-20-2015, 08:59 PM
BigMasterCheese
Thank you, that is a big help. I had no luck at the auto store this weekend.
  #28
Old 09-22-2015, 11:27 AM
BigMasterCheese
Here is the original part number C4TE-8594-B, maybe it will help someone else in the future.
anavrinIV
83
05-18-2021 11:18 AM
fladoodle
05-30-2019 11:46 AM
bmoore79
10-01-2018 04:10 PM
Boltgun
40
06-02-2017 10:13 AM
BishopRyan
15
05-15-2008 08:21 AM
Quick Reply: WWYD 1957 F100
