New fuel tank
New fuel tank
On my 04 Navigator I had a full tank of gas and parked on my driveway with the nose down. After my wife left in the morning I noticed a wet spot in the middle of where the vehicle was. It turned out to be gas. I took it to my father-in-laws who owns a salvage yard to put on a lift. Took off the tank and there are two vapor check valves that each have a crack under where the hose connects to. So I called two different Ford dealers and the both said I would have to buy a new tank ($1300) because you cannot just buy a new valve. So my father-in-law has an 03 Expedition tank available and swapped out into my Navigator. Is there not anyway to change out just the part and not be forced to buy a new tank?
Does it look like this?
Amazon.com: F67z9b593ca Fuel Tank Vapor Vent Check Valve Oem Ford: Automotive
When I dropped the tank to replace a fuel pump, I had cracks in the tank at two of those valve openings. I cleaned the tank, applied JB Weld, cleaned up the excess, and installed the pump and tank.
Repairing the cracks fixed my EVAP monitoring system too as it would never set regardless of the drive cycles.
