speakers
Old Jul 31, 2003 | 01:42 PM
adidasab03's Avatar
adidasab03
speakers
I have a 2000 Ranger single cab. I also have a pair of Sony Xplode 6x9s. I tried to put them in and i noticed that there was not enough room because the magnet was against the metal. Would this cause a problem with the speakers or will i have to build a box?
Old Jul 31, 2003 | 02:08 PM
greenpus's Avatar
greenpus
speakers
If you can bolt them in it will probably work but I would expect since the magnet is touching the metal it will cause an annoying vibration that will drive you nuts.
Old Jul 31, 2003 | 10:28 PM
oduke's Avatar
oduke
speakers
Try spraying a thin layer is Undercoating to cover the metal that the magnet is touching. Maybe this will stop/prevent vibration noise(s).
good luck
Old Jul 31, 2003 | 11:13 PM
LV96's Avatar
LV96
speakers
Construct a wood mounting bracket about the size of the hole, so it will give you another 1/2 - 1" clearance.
Old Aug 1, 2003 | 11:53 AM
WXboy's Avatar
WXboy
speakers
You mean you tried to replace the factory speakers with 6x9"s?? If that's what you mean, no wonder it didn't fit....that's the wrong size for these trucks. The OEM speakers are smaller.
Old Aug 1, 2003 | 07:49 PM
Rancha9's Avatar
Rancha9
speakers
The super-duper 5x7/6x8 is the stock Ford size now... You'll need to space out those 6x9's to get them to clear the sheetmetal (the stock 6x8's are close enough), go get some 6x8 X-plod's, or cut out the rear speaker mounts and install 4 8" subs behind the seat... I chose option 3 (I was bored that day)
