Riddle me this. CPS problem
Old Nov 17, 2012 | 01:45 PM
Talyn's Avatar
Talyn
Okay, I'm getting the CMP fault code, or CPS fault code.
Which coorilates with my stutter while running after starting.
Why is the CPS just momentarily failing and running fine otherwise?
I checked the wiring today, not a wiring issue.
Truck runs great (cept for my serpentine belt squeel)
So....
Why am I getting the momentary fail, but the truck going fine otherwise?
I think its during the idle down change.
Thoughts?
Old Nov 17, 2012 | 05:24 PM
Hussler's Avatar
Hussler
WAG, maybe a fuel issue. PCM pretty much controls everything but doesn't know anything about fuel pressure, nor does it care. It just assumes the pressure is there and if it can't maintain commanded rpm I can see where CPS might be blamed for the fault. Once again just a WAG .. maybe air getting into the fuel system after shutdown?
Old Nov 17, 2012 | 06:01 PM
Talyn's Avatar
Talyn
It's completely random, but always on a cold start up.
It's definitely not a fuel hick-p.
It's a good guess, but I'm not thinking so. That would usually mean a hard start as well.
Old Nov 17, 2012 | 06:03 PM
Action4478's Avatar
Action4478
IIRC ,Code is only set after 7 seconds of no sig...
Which code was set ?
P0340: Inactive CMP signal detected during engine cranking when ICP pressure was sufficient for starting.
P0341: Electrical noise detected, check wire routing and grounds.
P0344: Incorrect number of sync to transition counts detected, possible intermittent CMP sensor/circuit fault.
Old Nov 17, 2012 | 08:20 PM
F350-6's Avatar
F350-6
When mine acted up, it would stutter at random going down the road. It felt like an intake backfire out of an old gasser. Just a split second stumble while I was driving. After 4 or 5 times during one drive,the CEL finally came on from a code. I don't remember which code it set, but a new CPS fixed me up (before they became so cheap).
Old Nov 17, 2012 | 08:56 PM
BuckHammer's Avatar
BuckHammer
When my CPS was failing, it was an intermittent stalling issue. It would run great for a hundred miles and then stutter once or twice, or if it was just idling, it would stall.
Whitey Ford
17
Jan 5, 2024 10:47 PM
Swat_Medic
May 13, 2018 02:20 PM
KH85
Jan 3, 2014 10:53 PM
blrman1962
Mar 8, 2013 04:12 PM
blrman1962
Jan 24, 2012 02:00 PM
