Body Mount Bolts
Old Jul 20, 2015 | 08:48 PM
afmedic's Avatar
afmedic
Originally Posted by Diesel_Brad
radiator support mounts have the hex in them
Ahh that's what it is. I'm going to work on it more tomorrow. I'm planning on spring the cab and cutting away the rubber so I can heat the sleeve and see if I can get it free
Old Jul 21, 2015 | 03:48 AM
Diesel_Brad's Avatar
Diesel_Brad
Just make the exhaust tube puller
Old Jul 21, 2015 | 02:38 PM
afmedic's Avatar
afmedic
Well I got all but one bolt out and I have to take a break from the heat. 3 hours for 3 bolts. This is crazy! I ended up heating up the nut on the rear bolts and they came loose no problem. Then I just used a sawzall to cut the sleeve in the middle so I could re use it. I think it'll do just fine.
Old Jul 22, 2015 | 08:28 AM
afmedic's Avatar
afmedic
Not sure if anyone needs the information or not, but I'll keep posting on here so that if someone needs it and does a Google search they will find it.
I got all of the bushings replaced. I had to torch the core support bolts out, and heat the rear cab mount nuts to get them to break loose. After getting the bolts out, I cut the rear rubber away so I could see the sleeve, and cut it with a sawzall right in the middle. That way there would still be sleeve left sticking in each half of the bushings.
The front cab mounts were easier, all I did was use a jack to push up on the body mount nut from the bottom until there was enough room above the mount to get the saw in. I cut the sleeve between the bushing and the mount, and they came right out.
All in all, not "difficult" but the rust and precarious angles make it very time consuming. I think I have about 12 hours of nonstop work in it right now.
The new bushings lifted my cab almost an inch and a half because of how squished the old ones were.
Old Jul 23, 2015 | 11:07 PM
LeoJr's Avatar
LeoJr
Yay! Are your cab body lines lined up with your bed body lines?
Old Jul 24, 2015 | 05:26 AM
afmedic's Avatar
afmedic
It certainly does!
Old Jul 24, 2015 | 05:28 AM
afmedic's Avatar
afmedic
It got a body lift too, only reason being that the body lift was half the price of what it would have cost for new body bolts and I had to torch a few out and cut a few others
Old Jul 24, 2015 | 07:38 AM
LeoJr's Avatar
LeoJr
It certainly does!
Looks good!
Old Jul 24, 2015 | 11:01 AM
arctic y block's Avatar
arctic y block
Now for a set of 33X10.5 tires.
The 12.5 tire just rubs a little
on my Bronk. Just sayin.
Old Jul 24, 2015 | 11:03 AM
afmedic's Avatar
afmedic
It is getting a 6" suspension lift in September. I think I'm going to go with 35s
Old Aug 21, 2015 | 10:46 PM
afmedic's Avatar
afmedic
Well no more work on the truck. She's gone. Sold her today and bought a 2000 excursion. Always wanted one, and got this one on a deal I couldn't pass up!
IDIoit
Sep 30, 2016 01:46 PM
Skip1970
Aug 17, 2015 02:19 AM
little Loopie
Nov 3, 2003 10:53 PM
STEVE1103
Paint & Bodywork
Mar 30, 2002 09:16 AM
