Road Trip Advice
The end of the month I am moving from Dallas, TX to Jacksonville, FL for a new job. I'm gonna make the trip in my '72 F100. Any advice for the road trip?
I am all up to date on normal things, have gone through the tires, spare, all fluids, etc. I'll have my tools with me. Won't be too weighted down with stuff. Not towing anything. She always seems to run coolest when cruising down the highway but the farthest I have ever gone is a couple of hours up to now.
I am interested in knowing the fuel mileage since I have 3.0 rear end. Kinda hoping I can get 15mpg if I keep around 60mph. Although I will have a 6 gallon fuel can with me in case me or the gauge is wrong.
Anyway, if you all got any advice, please pass it on.
Thanks
Extra parts: Ignition control module, a starter solenoid, fuel filter, fuses.
Tools: Basic tool set like sockets, wrenches, screwdrivers, dikes, long nose pliers, etc. LED flashlight or wearable light. Tire repair kit (for a 4x4).
I have a $30 tool kit from HF in each vehicle.. just in case.
Stuff: Fire extinguisher, jumper cables, automotive wire, bailing wire, duct tape. Two quarts of oil and one gallon of coolant mix. Extra drive belts.. I keep my old ones for spares.
Stuff: add a pile of zip ties (they have saved my *** more than once), a flashlight, and a tow strap. If you have the room a small electrical repair kit butt connectors male and female terminals etc. Also a well stocked box of spare fuses and a spare fuse able link.
Multimeter or at least a test light.
spare tire with correct socket or star wrench and adequate jack with handle to change a tire (not all these old trucks still have the original or correct tools for changing a flat)
Small adjustable crescent wrench
screw drivers
wd40-can use to get moisture out of distributor cap
rags
bailing wire or zip ties or duct tape
coil
jumper cables
fire extinguisher
pen and paper-might need to write down part numbers
cell phone
a real bottle jack
hammer
1-2 driveline u-joints and extra straps/clips/u-bolts
couple feet of 3/8" fuel hose, 3/8" oil hose, vacuum hose and corresponding hose clamps
Do a nut/bolt integrity check, front to back and retorque the lug nuts.
Paper towels and glass cleaner.
jumper wires
in the back window. And yes pack a hand gun
only if your used to using one. And don't pull it
out and just wave it around and point it trying
to scare the bad guy. If ya have to pull it than
be damn ready to use it.
Either way, in your estimates, definitely aim low.
Check all your radiator & heater hoses also the water pump by pass hose and replace them all a long with all the those belts. Clean cooling system if needed. Put in new air filter.
I always keep in my toolbox a 4ft. length of a 14-16 ga jump wire with alligator clips on each end in case something needs to bypass something when needed.
You don't need to take more crap then what may be needed with you if you do a good preventive maintenance first.
One thing you may never thought of but, make sure all your axle & tranny vents are not filled with dust, mud or dirt. As your oil fluids get hotter they give off vapor gases and if you venting holes are plugged. Say the rear axle vent those venting gases will push out pass the axle seals that will sometimes push gear oil out with it..
Then you'll end up with possibly getting it on the brake shoes
Also check front wheel bearing, clean an repack them install new hub seals.
Lube tie rods king pins u-joints, Brake fluid, check all running lights H & L beam & tail. Also check windshield wipers blades fill washer fluid. Air up all 5 tires.
Well that should get you there.
And a few gals of drinking water that can also be used in the rad if needed.
Orich
I used a yellow high lighting pen marking my way from Point A to B the root I'd be taking.
I would fill up the tank about every 100 miles to always to be on the save side of not running out in my f250 4wd with 410 rear 11.5 x32 tires.
I only took a extra 5gal. of gas two times and never needed it in the 25 yrs of having the camper on. But by filling up when my gas gauge was down to haft tank. Plus it having all the family members & dog to take care of business.
Ah yes it slow going when your traveling with your family but it made the trip more enjoyable with the wife is in a good mood.
So now to my point when you see a road side sign stating next gas 100 miles+ you better gas up even when the price is marked up pretty high. I beats running out of gas a long the road side. Or buy a few gallons to be on the save side.
Orich
Easy for me to say because I have a stock pile of farmed parts, an extra distributor?
I keep one behind my seat.
2X on the drinking water.
3X on the gas stations. I'm not sure the route, take the advice of highlight your route and in another color highlight your estimated refuel
I would just take a few basic hand tools, some jumper wire, a tire plug kit and compressor, maybe a spare belt, and as mentioned, plenty water. It's not like you're going through the desert, but it is summer! Maybte take a quart of oil, transmission fluid, etc. Most likely problems are a busted hose, clogged fuel filter, dead battery, or bad alternator. Those can leave you on the roadside in the heat if you're not prepared. Maybe take a few spares for parts you can't get easily at the parts store. Duct tape can temporarily patch a hose. And don't forget your cell phone and charger! Enjoy your road trip!
