LED cup holder lights
Old Jul 18, 2015 | 04:08 PM
gcan's Avatar
gcan
has anybody installed a LED cup holder light kit? I purchased a kit, have tried to install it twice and failed both times.
I get the light attached to the cup holder with the RTV silicone but the cup holder will not snap back in place with the light string in the groove.
It seems the light string is to thick for the cup holder to snap back in place on the shifter cover. It's says it will fit my truck?? My truck is a 2014 and I've only had it for about a month so getting out the tremel is not an option.
Tried twice and for hours.
Am I missing something?
Old Jul 19, 2015 | 06:48 AM
steven2848's Avatar
steven2848
I had to drill 2 small holes on the plastic frame at the back of the back of the cup holder, so the 2 light strings drop down inside the armrest. If I remember correctly, the instructions illustrate this.
Old Jul 19, 2015 | 08:56 AM
gcan's Avatar
gcan
I drilled a notch for the string ends......mine doesn't snap back in place like the light string is to thick.
If you installed the kit I assume you had no issues snapping the holder back in place?
What year is your truck?
I read in another thread where somebody also with a 2014 FX4 had the same problem as me....may be a truck year/model issue but you would think the seller would know what it fit
Old Jul 19, 2015 | 09:00 AM
steven2848's Avatar
steven2848
I have a 2014 F 150 FX4 Supercrew 4X4, interiors may be different on different models. Had no problem with it snapping back in.
Here's what I installed: http://www.f150leds.com/f150-cup-holder-ring-kit
Old Jul 19, 2015 | 10:25 AM
gcan's Avatar
gcan
yep i have the same vid and followed to the letter....like I said getting the light string attached to the cup holder was no big deal it just will not snap back into place. I even got a screwdriver and tried pressing on the holder where the clips snap in but it would not attach. Pulled the light off and snap fell right in place. I've done this twice over the last two weekends even thinking the RTV wasn't cured enough so I let it sit for 3 hours then tried and the same just will not snap in......what a shame I think it's a great mod if it worked..and if the RTV didn't look bad......maybe I should try to tremmel off the clips a bit??
Do you have a picture of yours?
resonateur
Jan 15, 2016 07:09 PM
jonrjen
Ford Truck Parts for Sale
Nov 23, 2009 08:57 PM
pete98cobra
Jan 18, 2009 11:26 PM
BADAS03SVT
Jul 8, 2008 06:55 AM
IZZYAZ
20
Mar 16, 2008 06:56 PM
