There was an earlier post by someone on tranny codes, located on the door frame, unforunately the code on my truck was not listed. Mine says T, and the axle code is 19. Exactly what do I have for a tranny and axle? The truck is a 90' 5.0 4x4.
You would have either the C6, which has D,2,1 for gear selectors, AOD, which has OD,D,1 as gear selectors, or E40d which has OD,2,1 for gear selectors with OD cancel switch on the dash.
You can automatically tell what manual you'll have. It would most likely be a 5-speed M5OD or the T-18.
