Tire Size
Old Jul 17, 2015 | 06:47 AM
gmhill33's Avatar
gmhill33
Tire Size
Greetings,
How much taller and wider are the 31×10.5's than a stock tire?
Thanks,
Gary
Old Jul 17, 2015 | 11:30 AM
mg94mg94's Avatar
mg94mg94
235-75R15 is about 29" tall and 9-1/4" wide. Thats without measuring though.
Old Jul 17, 2015 | 12:17 PM
gmhill33's Avatar
gmhill33
So you gain a couple inches in height by switching to the 31's. Those can be put on the stock rim?
Thanks,
Hardy
Old Jul 17, 2015 | 12:19 PM
mg94mg94's Avatar
mg94mg94
IIRC, people use them on the stock wheels, but they rub a little on tight turns.
Old Jul 17, 2015 | 12:23 PM
Nothing Special's Avatar
Nothing Special
General rule of thumb is that the rim width should be about 2" less than the tire section width. So a 10.5" wide tire should be on a rim that's 1.25" wider than the rim for a 9.25" wide tire.
However, that general rule of thumb isn't a hard and fast rule. you can put that tire on the stock rim. It MIGHT wear faster in the center, and it MIGHT not handle as good as it should. But you might not notice anything either. A lot of people do go even wider than 10.5" on stock rims.
Old Jul 17, 2015 | 01:52 PM
mg94mg94's Avatar
mg94mg94
According to the book at work, the safe rim sizes for a 31x10.50r15 are any J type from 7-9"
Old Jul 17, 2015 | 02:09 PM
gmhill33's Avatar
gmhill33
Thanks everyone for the replies.
My questions now are. What is the proper size rim for the tire and is there anyway to make it not rub?
If you haven't figured it out by now, this is my first truck.
Thanks,
Gary
EDIT: One more question. To measurer the size of the tire, do you measurer around the tire or the height from the ground to the top of the tire?
Old Jul 17, 2015 | 02:55 PM
GocartMozart's Avatar
GocartMozart
I am running 31x10.50R15 on stock 15 x 7.5 inch steel rims. No rubbing whatsoever. They handle great all around. 1995 F150 4x4. Might handle a little different for RWD though.
Old Jul 17, 2015 | 03:45 PM
gmhill33's Avatar
gmhill33
Thanks for replying. Mine is 1995 f150xlt Flaseside 2wd.
Thanks,
Gary
Old Jul 17, 2015 | 05:26 PM
mg94mg94's Avatar
mg94mg94
31 - 31" tall
10.50" wide
15" rim
Now here is where it gets interesting. For 235-75R15
235 is the tread "section width" in mm
75 is the aspect ratio, meaning the sidewall is 75% of the section width tall.
15 is the rim diameter.
So to get the total height, you have to do:
(235x0.75x2)/25.4 +15
The 2 is for 2 sidewalls and the 25.4 is to convert mm to inches.
Old Jul 17, 2015 | 05:37 PM
gmhill33's Avatar
gmhill33
Originally Posted by mg94mg94
31 - 31" tall
10.50" wide
15" rim
The only thing that comes to mind is "WOW"! Thanks for the break down. I would have never figured that was how you got the height of your tire. So the 31" are considerably taller than the stock tire. That makes me want to get them even more.
I have another question (maybe I should start another thread). I have looked online for a leveling kit for my truck and it seems that it is only two springs. Is there anywhere that I can find the height of the springs? I have a brand new spring that i am going to put on the passenger side and would like to know the difference. The guy I bought the truck from bought two front springs but only one spring tower so I'm going to get the other spring tower to level the truck with the drivers side.
Thanks again for everyone that has replied.
Gary
Old Jul 17, 2015 | 09:26 PM
gmhill33's Avatar
gmhill33
After reading a few different post will the 5.0 be enough if I put the 31x10.5's on?
Thanks,
Gary
Old Jul 18, 2015 | 09:21 AM
Kanglar's Avatar
Kanglar
I had 31s on my f150 with the 5.0 with no problems. It was a 4 speed and could still do a little bit of a burnout.
Viger81
Jan 13, 2017 11:28 PM
cajunfuse
6.7L Power Stroke Diesel
17
Jan 31, 2014 10:28 PM
mck2000
Jan 16, 2012 10:57 PM
m1e9r5c6
Sep 15, 2009 10:49 AM
nebechanezer
Feb 4, 2006 12:09 AM
