this is my first post on the ranger section I own a 82 f100 as well and i am over there all the time but now it is ranger day.
so i have a 1986 ranger 4x4 supercab with the wing window and It does not have a passenger side window. I bought a window from the pick and pull with the track still attached to it on the bottom. but when I was takeing the older door apart and i am in the middle of figuring out a way of removing it with out breaking any other parts to get the other one in and I am stuck.
I cant figure out how to take the old track out and replace it with the one with the window still attached to it. Any help will be very appreciated. thank you
i got it in finally by taking out the long silver verticle track and finagaling it straight down. but man it was mean to get the be perfect. who ever tries this next it is best to remove the verticle track from the bolts so you can manuver it around. then to try and get the square track block off of the windown track slide. and then pull the pieces out.
who ever sees this next i wish them good luck and it can be done with out breaking pieces so dont give up
