Speedo Jumps
Old Jul 15, 2015 | 11:57 PM
EP145's Avatar
EP145
Speedo Jumps
Hi, My speedo in my 73 was jumping around and making noise so I lubed the cable and the back of the speedo and it helped for awhile. Now sometimes it will jump for awhile and then works fine. Any ideas on what I should do I used graphite on the speedo and cable.
Old Jul 16, 2015 | 12:11 AM
HIO Silver's Avatar
HIO Silver
Jumpy speedos are typically caused by a damaged cable... a kinked cable in the sleeve grabs and then when enough twisting force is applied it releases which is causing the indication to spike. The likely solution is to install a new cable.
Old Jul 16, 2015 | 09:45 AM
Ozzie H.'s Avatar
Ozzie H.
I agree. Problems can also be caused by dried lubricant or cables with sharp bends. Whatever the reason, a new cable & sheath, installed properly, will likely cure the problem.
Eharang
Apr 2, 2020 05:31 PM
72sportcustom3906.4l
Jun 20, 2009 05:56 AM
64fordf100292
Sep 16, 2007 07:20 AM
Greg H.
36
Apr 11, 2007 12:59 PM
GT40Cougar
Jul 26, 2004 02:39 PM
