351w head i.d.
Old Jul 31, 2003 | 07:20 AM
HAL_419's Avatar
HAL_419
351w head i.d.
Need your help in identifying some heads that have "WINDSOR" cast in them in the rocker section. Also, they have red roller rockers as well.
Not sure what cam was installed. Just know that the engine was rebuilt at a local speed shop b-4 the engines owner passed away. The engine was only test run. Out of the vehicle
Can anyone help and tell me anything about them.
There mounted on a 351w engine with a "Edlebrock victor jr." manifold, with a Holly (? not sure which one) dual feed carb.
The engine has D8 cast in the block.
Any and all help will be appreciated. I plan on putting this engine setup in my 92 F-150 4x4 w/e4od.
Also, what do I have to do to make the the swap and keep the same trans, (e4od)
Thanks, HAL_419
Old Aug 1, 2003 | 01:27 AM
Jimbo302's Avatar
Jimbo302
351w head i.d.
Iron? Might be a world product. Is that the only casting?
Old Aug 1, 2003 | 06:36 AM
HAL_419's Avatar
HAL_419
351w head i.d.
This is the only info "WINDSOR" cast into the rocker area. There is a date stamped on the front right end of the block "1988".
As for the engine block, the casting #, it starts out as "D4" rather than "D8"
The engine casting # is D4AE-8015-AA-4, the small # below this is" *658 " from what I can see. I'm not to sure about the (*) b-4 the numbers though. All help is appreciated.
Thanks, HAL_419
92' F150XLT 4X4 302 E4od ( soon to be 5.8)
Old Aug 3, 2003 | 04:34 PM
Aekisu's Avatar
Aekisu
351w head i.d.
1975-80 351W Bore 4.00" Deck Height 9.503
Are you sure the casting number isn't 6015 instead of 8015?
I just pulled this info out of a book. It could be in error.
