Explorer Block Heater
Old Jul 31, 2003 | 01:13 AM
Greg McFadden's Avatar
Greg McFadden
Has anyone installed a circulating type block heater in a 1995 Explorer? Can it even be done? So far, all that I have found is freeze plug heaters, which I doubt will heat the block enough (moving to Minnesota). Specifically, I have been unable to find an accessable coolant drain plug in the bottom of the block to hook the heater too.
If anyone has any hints, advice, I would appreciate it.
Thanks
-Greg
