A/C vent issue
Old Jul 12, 2015 | 11:59 PM
pigpen6214's Avatar
pigpen6214
Question A/C vent issue
I recently installed an egr delete and ever since, my vents have been stuck to the upper dash no matter which setting I put the **** on. The vent will push the air conditioning, regular air and heat all the same. I have checked the fuses and they are all good. Any ideas?
Old Jul 13, 2015 | 12:06 AM
87crewdually's Avatar
87crewdually
Check the vacuum line on the passenger side near the HVAC box. Verify there is vacuum present.
Old Jul 13, 2015 | 07:03 AM
dannyboy950's Avatar
dannyboy950
I agree when there is no vacum a/c defaults to defrost. Blows only on the windshield.
Old Jul 15, 2015 | 06:13 PM
Kemicalburns's Avatar
Kemicalburns
interesting, My AC only blows out the front vents. I was surprised it didn't also blow out from under the dash so maybe I have a line disconnected?
Old Jul 15, 2015 | 06:35 PM
Rusty Axlerod's Avatar
Rusty Axlerod
The default position (no vacume applied) is through the defrost vents. You could have no power to the vacume pump, a bad pump, disconnected or leaking vacume lines, or leaking front hubs if your truck has automatic hubs. Step one is to verify the pump is running.
Old Jul 16, 2015 | 04:20 AM
Danner717's Avatar
Danner717
I had the same problem. Only when i put it in 4wd it would go to defrost only and back to normal when i took it out. Ended up being the vacuum pump was going bad.
JasonBrod
38
Jun 24, 2018 05:57 PM
shortcakemedic
1997 - 2003 F150
Jul 30, 2017 04:30 PM
BlackSwan F100
Jul 8, 2014 01:11 PM
rockos3354
Escape & Escape Hybrid
Sep 19, 2010 11:47 PM
probation144
1983 - 2012 Ranger & B-Series
Mar 3, 2002 06:40 PM
