f250 will not start
Old Jul 12, 2015 | 09:02 PM
Harris Michael's Avatar
Harris Michael
f250 will not start
i have a 1987 ford f250 , i was moving the truck across my lawn , and it just died, it started hard and just barely ran , now to the next point then died again, now the truck will not start , it will start just a little with starting fluid, just a little . now not at all, but the strange thing is the tachometer moves all by itself with the ignition in the run position , it moves all over the place and when i crank it , it will go around in a circle , any suggestions on what to look for, thank you all.
Old Jul 13, 2015 | 05:12 AM
redford's Avatar
redford
FTE Leadership Emeritus
Moved to 1987 - 1996 F150 & Larger F-Series Trucks forum.
Welcome to FTE and good luck.
Old Jul 13, 2015 | 04:41 PM
'89F2urd's Avatar
'89F2urd
The pip sensor is located inside the dizzy and it sends signal for the tach operation. Sounds like yours is bad, preventing it from running as well as funkifying your tach readings.
Old Jul 13, 2015 | 05:42 PM
Harris Michael
ty
tyvm now what is a dizzy ?
Old Jul 13, 2015 | 06:03 PM
JWC 3's Avatar
JWC 3
Distributer . Dizzy .
Old Jul 13, 2015 | 06:07 PM
Harris Michael
tyvm i will install a new one
Harris Michael
Jul 13, 2015 05:21 PM
Javo
May 28, 2012 08:17 PM
viperrtblck
Nov 17, 2006 01:08 PM
Klangmire
Jan 7, 2003 07:48 PM
