Headlamp Problems(could it be the lowm?)
(some background)
a couple months ago my left lowbeam went out. checked everything, and couldnt find the problem source, so i created a run from the other low beam wire to the left low beam, and now this past weekend both went out.
Ok so I ruled out the fuses(checked both boxes), the bulbs(checked both), and my light switch on the steering column(figured if it was this in the first place then both lamps would have went out the same time prior). The only thing many people can come up with is the lowm . Where exactly is it under my message center? I'm taking my 95 ford explorer to the ford garage on the august 6th(thats the only time i could into the dealer). To run the diagnostics and figure out what they think is wrong will cost my $54.
I personally would prefer to buy the module save $54.00 and put that towards the module itself.
Also I can't find anything on it in my chiltons manual or cd.( yes i also read this in a few other posts.
Help would be greatly appreciated.
Thank You.
