summer help for your radiator
Old Jul 9, 2015 | 08:32 PM
dannyboy950's Avatar
dannyboy950
Summer time is definitely here and cooling issues are multiplying as useual
Some tips to help improve the efficency of your cooling system in this heat.
Heating and airconditioning people found years ago that cleaning the outer surfaces of the condenser
coils would greatly improve the heat exchange efficency. Once a year just before summer they will wash thru the coils with a coil cleaner soloution. Even if not obstructed by debrie oxidation would build an insulateing layer reduceing the effectiveness of heat exchange.
This applies just as well to radiators. Cleaning the tubes and fins will help a good bit.
While this works better removeing the radiator and being able to wash straight thru the fins and coils/tubes however you can do a passable job with it in place.
Useing a common garden pump sprayer mix a water/cleaner soloution according to the directions plus just a little more water. Spray this on the exsposed surface of the radiator and the a/c condenser.
Let set a few minutes and then was out and thru the surface as best you can with a water hose and short low pressure nozzle.
Removeing the flat plastic cover between the radiator and crossbar you can actually get to the radiator pretty good. Or you can wash straight thru the front grill and condenser. It just takes more time and water.
You will be surprised how well this helps the cooling system.
Old Jul 9, 2015 | 08:37 PM
LivingLarge's Avatar
LivingLarge
Nice post, reps sent
Old Jul 10, 2015 | 06:06 AM
KES08's Avatar
KES08
Great post! I'd like to do this, where did you get the cleaner?
Old Jul 10, 2015 | 08:46 AM
dannyboy950
I have found it at hardware stores; A/c supply stores; wwgrainger etc.
Use with caution these are acid or caustic based. Health and physical hazard.
Too strong a concentration or if left too long can actually disolve thin aluminum.
Old Jul 10, 2015 | 11:08 AM
mattdoc88's Avatar
mattdoc88
Old Jul 10, 2015 | 04:20 PM
dannyboy950
I neveractually used any of the spray foam type cleaners I always bought it by the gallon and you mix it yourself.
However I have heard good things about the caned spray foams.
brassplyer
Jan 23, 2019 02:21 AM
chad77
Jan 5, 2017 08:38 PM
genscripter
Apr 13, 2016 06:14 PM
Jrock909
Jan 30, 2007 11:14 PM
MadMedic20
Sep 14, 2004 06:33 PM
