About 5 years ago I paid to have a 300 built and the engine failed. The oil pressure started dropping until it reached, iirc, 4 psi at hot idle. That happened within 1k miles after the rebuild. It has been sitting in my garage, on a stand, since. Today I will tear it down and hopefully find out what happened.
Is this the engine with the valve cover which had been media-blasted and possibly had left over media lurking in the baffled areas?
Yes, it is that engine. Regarding that theory: We changed the bearings and the psi continued to drop. Maybe I will never find out what happened, but it is time to get it out of my garage.
If I could find a cause then I would be able to sell the parts that I knew would not cause problems.
Good luck with your investigation. Some have reported poor bearing surfaces on camshafts purchased from a particular supplier. The literally rough surfaces ate through the bearings.
Yes, I have read about infamous Clifford cam cheese grating bearings. Mine is an Isky cam.
Well, I'm surprised, and disappointed, that everything looked fairly good. The possible issues I noticed I'll list and let someone with more experience than I possibly diagnose.
1. On a couple of the ARP rod bolts the machinist did not press them all the way in. The bolt head remained 1/8" from seated.
2. Cam bearings showed visible wear line.
That is not a shadow. I could feel an 'edge' or difference with my finger on that line.
3. The thrust bearings. Both sides were to copper, with only about 500 miles on the engine. I also noticed rough areas on the crank where it rides the side of the thrust bearing. Hopefully you can see it in the photos.
4. Over all, for an engine with dropping oil pressure down to 4psi, it looked good. That rough area(s) on the crank at the thrust journal is the most distrubing.
BTW, I came across a factory plugged hole at the bottom of the block, right below the dip stick hole. Does anyone know its purpose? It goes straight through the block.
The bore was perfect. The pistons and rings were good.
For future reference, when I remove a bearing and it says .010, how do I know whether that is over or under sized? Is it merely a visual inspection, noting which side is thicker?
.010 on a bearing would mean that the crankshaft has been turned to .010 undersized. Thus, the bearing is thicker to keep the centerline of the crank in the same position as it was at full diameter.
Thanks. So under-sized bearings simply say .010, or whatever has been removed from the crank.
What does an over-sized bearing say on it? An over-sized bearing would be used where the crank journals had been machined to a larger diameter than oe, correct?
I'm also wondering, if I send out a crank to have it turned down .010, do they resurface or turn down the surface that touches the sides of the thrust bearing?
The crank can't be machined to a larger diameter. (think about it....)
Cranks are resized by welding, and that was the way to make a stroker in the good old days.
I can't think of a good reason anyone would want larger journals, as that causes issues with the block and rods. You can, and it is often done, swap to a smaller journal on the rods so you can use an off-the-shelf rod. Most common for V8 performance would be the BBC rod or rods that size so you can buy standard bearings.
As for the thrust bearing surfacing, best ask the machine shop how that is done and figured. End play being pretty important, I'm sure there is a "standard" way that is handled. No one mentions it much, but it's gotta be dealt with.
I did not say 'crank machined to a larger diameter.' I went back and reread what I wrote.
I wrote 'crank journal', which, unless I am greatly mistaken, is the cap, the part the bearing and crank sits in and is clamped down over the crank. Unless my reading has been wrong, the journal does get line honed on occasion? Hence, over and under sized bearings. One, in essence, replaces material removed from the crank (under-sized), the other replaces material removed from the journal (over-sized), the cap.
At least that is my understanding, and I certainly am still learning.
So I'm still looking for an answer to my original question: how do you still the difference between an over and under sized bearing?
But I see what you mean. When a rod is resized or the block line-bored, how do you fit bearings?
Seems that with the mains, the main caps are cut down a bit, then bolted to the block. This result in a smaller hole which is then bored out to the original size. Tricky work, especially with cam bearings where oversized bearings or cam journals are required, or with OHC heads. More on that subject:
So, at this point, not finding anything wrong with the block after checking with a light, is this block buildable? It did make me feel better to find the questionable machining marks on the crank. At least I have a suspect.
After spending $400 on the machine work, could I have a clear conscious selling it? I also have pistons with 1k miles on them with Chrome molly rings, balanced, reconditioned rods, with ARP bolts.
