I have tried all the "normal" stuff. Heat, PB Blaster, different sockets. The bite-into-rounded-nut tool I own won't work because the tool OD is too large for the hole in the flywheel.
Where I am now: well-rounded nut.
Thoughts would be appreciated.
Is the stud easily replaceable, if I bung it up in the process?
I have never pulled a torque converter on any vehicle, ever.
that's a real bugger too because you can't get a set of vice grips on it due to being recessed in the trans.
what you want to do is carefully,slide the trans back.leaving the converter on the felxplate.now with the trans back out of the way,you can heat it up good.clamp the vise grips onto it like you really mean it,nice and straight and give 'er hell.
ideally you would have slid the trans back before you totally rounded the nut.then tap on a 6 point socket then she would have listened.now your pretty much stuck with a nut splitter or the grips.or perhaps using a chisel and start smacking it to cut into it and it might spin off that way too.first things first, is to get the trans down and out,or at least way back.just be careful and keep the trans loose.don't lower too much before you bring it back or you'll bind things up and could cause damage.
be careful with the threads.take your time.if you frig them up,you'll just have to bolt it back up with 3 nuts.not the end of the world but ideally you'll save the stud.
This is a frame-off. The tranny is way off the truck. But the nut is recessed into the flywheel. I have not tried vise-grips, but I will. I suspect, access won't allow vise grips, even long-nose models, to get to the nut.
