AC problems.
Old Jul 8, 2015 | 01:57 AM
Chado101's Avatar
Chado101
AC problems.
So just bought the van a while ago. And need a ac...
So here's what's it doing.
First it does not blow cold. But hot setting will blow hot when it does blow...
It does not always come on when I try to turn it on. It actually doesn't work more then it does.
This problem is for all settings including defrost, floor, low high.
IT DOES NOT SWITCH TO DEFROST RANDOMLY.
also I had engine running issues which have since been solved. So smoke test have been performed although I'm not sure if they would have tested the ac system or not.
Any thoughts?
Old Jul 8, 2015 | 05:38 AM
JWA's Avatar
JWA
Your description is a bit confusing or unclear.
From what I can deduce there are possibly two different issues, first one being intermittent blower operation, the second being no cold air---are those the extent or are other issues also present?
Old Jul 8, 2015 | 11:48 AM
guitarpicr's Avatar
guitarpicr
Can u check wiring at the main switch - Make sure nothing is burnt or shorted/loose there. Just a guess - Be an easy check
Old Jul 8, 2015 | 12:39 PM
Chado101's Avatar
Chado101
Yes. That is the extent and about somes it up.
Not blowing cold and a intermittent blower problem
Old Jul 8, 2015 | 12:41 PM
Chado101's Avatar
Chado101
I'll get a chance to look later and get back to ya
Black Ford XLT
53
Apr 29, 2025 12:20 PM
majorgator
Jul 12, 2015 06:41 AM
ToreadorTalk
Jul 8, 2010 11:08 AM
brownie83
Jun 4, 2010 12:24 PM
f100guy
Dec 5, 2003 12:25 AM
