Sponsored by: Real Truck
Rocker arm
Old Jul 4, 2015 | 08:19 PM
Glenn.b1's Avatar
Glenn.b1
Rocker arm
1999 F250 Superduty Triton V10
I have a miss on #5 so I changed all the plugs & #5 coil. I then got a miss on #5 and random multiple misses.
Next step was to do a compression test on a few cylinders, which was fine, didn't write them down. But #5 compression was "0". I then pulled the RH valve cover off and found what I expected, the second to the last, intake(?), rocker arm laying in the head.
I ordered a new rocker arm and lifter & gasket. How do I get it back together?? I read about a special valve spring compressor for this engine series but it is #5!! Right next to the evaporator box.
Any suggestions would help big time.
Old Jul 5, 2015 | 05:33 AM
Just Strokin's Avatar
Just Strokin
might can rent a tool from local parts stores. The Ford tool in the photo uses a ratchet to actuate the valve spring compressor.
Old Jul 5, 2015 | 09:32 AM
Glenn.b1's Avatar
Glenn.b1
I'm a little confused. is the spacer (303-382) a guide, of sorts, or are you pushing on the spacer? I would think you would need to push on the valve spring retainer, on top.
Old Jul 5, 2015 | 11:38 AM
Glenn.b1's Avatar
Glenn.b1
OK I see. Spacer limits travel and push on valve spring retainer.
Old Jul 5, 2015 | 02:46 PM
Just Strokin
prevents you from compressing spring too far and the valve keepers come off dropping valve into cylinder.
Old Jul 5, 2015 | 05:09 PM
Glenn.b1's Avatar
Glenn.b1
I decided to do without a $35 to $40 piece of plastic that i have read breaks anyhow. I'll make sure there is a rag over the drain hole.
Marneaus
21
May 6, 2019 11:40 PM
JLHersh
May 13, 2018 04:21 PM
dkoszela
Aug 20, 2013 09:19 PM
daddy172005
Apr 13, 2009 11:58 PM
firefiter
1997 - 2003 F150
13
Feb 16, 2004 10:13 AM
