Sponsored by: Auxito
Temp. gauge in cab
Old Jun 18, 2007 | 10:10 PM
cajun1965's Avatar
cajun1965
Temp. gauge in cab
I just bought a 2000 f-150 2wd 4.6L V8 I am getting out of an 87' ford F-150 and alot has changed under the hood. My temp. guage in the cab will not move much off of cold while i am running for long periods, I changed the thermostate, checked the coolant level and all seems ok. Can some one tell me where the sensor is that sends the temp to the gauge?
Old Jun 18, 2007 | 10:29 PM
nascar88ford's Avatar
nascar88ford
They very rarely move anyway. The only time my temp guage has moved up past the normal setting is when I had an air bubble while I was doing a coolant change. I wouldn't worry about it.
-Matt
Old Jun 18, 2007 | 11:04 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The temperature sensor actually measures the temp of the head, and not the coolant. It's located on the top-front of the driver's side head
Old Jun 18, 2007 | 11:09 PM
cajun1965's Avatar
cajun1965
Well It never even gets to the normal range, I thought it read block temp and not coolant temp. but I was not sure.
Old Jun 19, 2007 | 10:55 PM
LxMan1's Avatar
LxMan1
Yep, it reads actual head temp.
bgab3
Feb 2, 2013 09:07 AM
cajun1965
1997 - 2003 F150
Jun 20, 2007 10:38 AM
tawd77
Feb 5, 2007 08:17 PM
97rangerguy
Apr 26, 2005 10:13 AM
97rangerguy
Apr 25, 2005 10:58 AM
