Sponsored by: Real Truck
Snap Crackle Pop
Old Jul 30, 2003 | 03:35 PM
F250reddog's Avatar
F250reddog
Snap Crackle Pop
Only had my truck a few months so I'm not sure if this is normal, but if I drive more than a few miles when I turn the truck off and get out I hear some crackling noises (especially on a hot day). Almost sounds like my Rice Krispy's in the morning. Obviously something is heating up. Just wondering if anyone knew the cause and if there is concern.
Old Jul 30, 2003 | 03:51 PM
FortyFords's Avatar
FortyFords
Snap Crackle Pop
Its the heat sheilds around the exhaust system ,
usually!
Most cars do it too!
Rich
Old Jul 30, 2003 | 03:59 PM
just_brian's Avatar
just_brian
Snap Crackle Pop
I agree with FortyFords, it's the exhaust components cooling down.
Old Jul 30, 2003 | 04:08 PM
hookspacken's Avatar
hookspacken
Snap Crackle Pop
My truck has done this fron day one. It still does it but not quite as long anymore.
Old Jul 30, 2003 | 04:30 PM
F250reddog's Avatar
F250reddog
Snap Crackle Pop
Thanks. That puts my mind at ease.
Old Jul 30, 2003 | 05:06 PM
JSWard's Avatar
JSWard
Snap Crackle Pop
Be very careful with this one. It is condensation hitting your heat shield but before it hits it it runs down the #6 injector. Which after a while will cause a short and it will have to be replaced.
Old Jul 30, 2003 | 08:31 PM
FortyFords's Avatar
FortyFords
Snap Crackle Pop
Condesation from what? a/c ?
How can that hit injector # 6?
please explain !!!!!! never heard of this.
Rich
Old Jul 31, 2003 | 07:59 AM
JSWard's Avatar
JSWard
Snap Crackle Pop
FortyFords:
I apologize for giving you the wrong number, the ac condensation will drip on or run over #4 injector. I know of 2 times that this has happened, and replacement was necessary. But it could bypass it as easily as it hits it I guess. Just something to watch for.
Old Jul 31, 2003 | 12:15 PM
sd99rhino's Avatar
sd99rhino
Snap Crackle Pop
The popping noises you are hearing are from your exhaust system and related thin metal parts. As your system heats up, these metal parts such as the pipes, muffler and heat shields expand so the noises you are hearing is the metal returning back to it's original form. It's all normal.
Old Jul 31, 2003 | 12:36 PM
mwpierson's Avatar
mwpierson
Snap Crackle Pop
I don't think it's the actual "metal" but the folds and welded areas.
Mike
Old Jul 31, 2003 | 12:52 PM
FortyFords's Avatar
FortyFords
Snap Crackle Pop
Originally posted by JSWard
FortyFords:
Thanks JS
I know we have had in the past a problem with the heater hose leaking on the coil packs and causing a problem !
good info ,thanks for the heads up!
Rich
fdnylax
1997 - 2003 F150
Nov 12, 2007 10:43 AM
BURNSTOUGHFORD
1997 - 2003 F150
Nov 6, 2007 10:20 AM
6spd
May 29, 2007 09:41 PM
david1951F1
15
Jun 1, 2005 11:24 PM
mike03
Exhaust Systems
May 12, 2002 11:08 AM
