starter replacement. ...
Old Jul 2, 2015 | 09:41 AM
ramirez7589's Avatar
ramirez7589
after a loud screeching sound that sounded like a spun shaft rubbing on metal iwent under and found the starter wabbling around. Its going to be a first for me. Anything out of the ordinary i should know before moving on with the replacement..
04 f250 diesel 6.0
Old Jul 2, 2015 | 10:45 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Not uncommon. Starter MAY be ok still. 3 bolts, one may be one missing completely. Top one is the most aggravating. For me a 8in extension with a deep well puts the ratchet in a place where I can get some swing on it. You'll have to work it by feel, you won't be able to see it.. Don't forget to unhook the batteries or you can make some pretty sparks .
Old Jul 2, 2015 | 04:57 PM
Jmoen7's Avatar
Jmoen7
Theres a couple threads on here about good upgrades, i don't know the numbers for sure. But the 6.4 starter will be a direct bolt in replacement. Plus it cranks smoother, and faster. Ive been meaning to get one because my starter is old and tired, doesnt matter how charged the batterys are its only hitting half the RPM a 6.4 starter will
Old Jul 2, 2015 | 05:09 PM
dannyboy950's Avatar
dannyboy950
Well tha is pretty well all coverd. Moveing on.
Old Jul 2, 2015 | 06:15 PM
69cj's Avatar
69cj
Ford had that same hidden third bolt fiasco with the old FE big block gassers. No biggy once you do it.
Old Jul 3, 2015 | 06:15 AM
GenMan's Avatar
GenMan
I have other things higher on my priority list right now, but here is a 6.4 starter I will be getting. price is good, free shipping, no core charge. LINK
Old Jul 3, 2015 | 05:05 PM
adammdennis11's Avatar
adammdennis11
04 f250 diesel 6.0
You'll need to go in threw the passenger side wheel well, remove the tire then the plastic lining guard and you'll have access to that top bolt. It will take some creativity to get that sucker out though.
Old Jul 3, 2015 | 11:32 PM
Tennesseepowerstroke's Avatar
Sounds like a plan. I will look at going this route next time.
Old Jul 4, 2015 | 12:40 AM
BryanStein's Avatar
BryanStein
Don't remove the wheel or splash guard. Starter change on the 6.0 is real simple. Yeah, you can't see the top bolt, but you can feel it and it's simple to get off and on.
It's a 15 minute job with all for ties I the ground.
Old Jul 4, 2015 | 09:29 AM
npccpartsman's Avatar
npccpartsman
Agreed. Takes longer to get the wheel liner out than it does to change the starter.
Old Jul 4, 2015 | 10:02 AM
KDAVID1's Avatar
KDAVID1
What size wrench for the wires to starter? Figured id piggy back here
Edit: looks like 10mm and 15mm
Old Jul 4, 2015 | 04:20 PM
Yahiko's Avatar
Yahiko
Here is a 6.4 starter thread. There are some Youtube run tests also.
https://www.ford-trucks.com/forums/1...t-for-fun.html
There is a photo of the starters that shows where the bolts are.
Sean
6.0L Tech Folder
Old Jul 4, 2015 | 04:30 PM
Macrosill's Avatar
Macrosill
That is how I did mine. A couple extensions and a flex head ratchet. Just make sure to disconnect BOTH batteries. I do both the pos. and neg. terminals on both batteries. I have seen a single terminal disconnected and within a couple minutes the cable slowly goes back into the shape it has been in for years and makes an electrical connection. All though, today is the 4th, LOL.
Old Jul 4, 2015 | 04:43 PM
KDAVID1's Avatar
KDAVID1
Glad I saw this post. Will be getting a new starter.
Old Jul 4, 2015 | 05:02 PM
Yahiko's Avatar
Yahiko
Did you watch the cranking video?
Sean
6.0L Tech Folder
