Motor mount
Old Jul 1, 2015 | 04:16 PM
ftrk66's Avatar
ftrk66
Motor mount
Hi everyone:
I wounder if the 240/300 I-6 engine mounts fits the 352 V8 installed in a 1966 F350 truck ( I mean the 2 on the sides). I couldn't find a place to buy such mounts or P/N to search. I appreciate any hint.
Old Jul 2, 2015 | 02:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Exclamation 1965/66 F350 352 and etc. motor mounts
Originally Posted by ftrk66
1966 F350 352 motor (engine) mounts
Following applications: 1965 F100/250 352 4WD ~ 1965/66 F350 352 ~ 1966 F250 352 4WD:
1) TFAA-6038-A .. Upper Front Motor Mount (rectangular steel/rubber insulator) / Obsolete
GREEN SALES CO. in Cincinnati Ohio has 21 = 513-731-3304 ~ greensalescompany.com
1) TFAA-6039-A .. Lower Front Motor Mount ('donut' shaped rubber insulator) / Obsolete
GREEN SALES CO. has 32.
2) C1TT-6A061-D .. Right/Left Lower Rear Motor Mount ('donut' shaped rubber insulator) / Obsolete
GREEN SALES CO. has 66.
2) C1TT-6068-C .. Right/Left Upper Rear Motor Mount (rectangular steel/rubber insulator) / Obsolete
AL WHITE MOTORS in Manchester Tennessee has 1 = 931-728-9700.
Green Sales ships 'across the pond' via Fed-Ex .. I don't know if Al White will.
Note: If typing these Ford part numbers into Green Sales' website, remove the hyphens!
Old Jul 2, 2015 | 05:49 AM
jowilker's Avatar
jowilker
I do believe the perches are the same (frame side). Replacements as per ND
John
Old Jul 2, 2015 | 06:26 AM
NumberDummy
John, there aren't any perches.
240/300/352: 1965 F100/250 4WD; 1965/66 F350; 1966 F250 4WD use a similar "3 point" engine mounting system as 1961/64 223/262/292.
240/300 parts not the same as 352 parts, but the assembly is the same.
Front: L shaped bracket bolts to the block. Two motor mounts, one below the bracket and above the cross member, one below the cross member.
Bolt passes thru the bracket, thru the upper mount, thru the cross member, thru the lower mount. Large flat washer and nut tie the whole enchilada together.
The bell housing has two "ears." Two lower rear mounts, one on the right, one on the left below the cross member.
Two upper rear mounts, one on the right, one on the left between the cross member and the "ears."
Bolt (1 per side) passes thru the lower mounts, thru the cross member, thru the upper mounts, thru the "ears." Flat washer and nut tie the whole enchilada together.
Old Jul 2, 2015 | 06:31 AM
jowilker's Avatar
jowilker
350 Aaaah yes, correctomondo.
John
jghelm
Jul 2, 2017 02:23 PM
gary737
Dec 15, 2015 10:08 PM
TheV8tractor
WTB - Parts & other
Jan 2, 2015 12:56 PM
Ron's'70F-250
Oct 10, 2009 05:41 PM
itsmywifestruck
Mar 14, 2009 07:24 PM
