Help Locating the Power Distribution Box 2003 Excursion
Hello,
I need some help locating the power distribution box on my 2003 Ford Excursion. I have looked everywhere and have searched and searched online with no success. I am trying to inspect some fuses i suspect might be blown as I have no power to my trailer plug currently. My Ex is a 6.0L PSD 4x4 if that matters at all. Thank you in advance.
I have continued researching online and it looks like now that Ford moved the Power Distribution Box on 2002-2005 models. I have located 2 small fuse boxed in the driver's side fender under the hood. One has just a couple relays, and the other has one mini fuse and 3-4 relays. Basically, my issue is that I have no power at all at the 7 Pin and 4 Pin plugs at my trailer hitch. Where should I start?
