Fuel problems
Old Jul 1, 2015 | 02:31 PM
Alanmats's Avatar
Alanmats
Question Fuel problems
I can't keep the engine running on my RV with a 1987 Ford Econoline 460 CID, carbureted. It's been sitting for several years, though I've started and run it on a regular basis. This time I can start it but it won't keep running unless I dribble gas directly into the open carburetor.
I've disconnected the fuel line forward of the fuel filter, run a hose from there and I can see gas pumping out of the end of the hose as I run the engine.
My question: does the flow from the fuel pump increase as the speed of the engine increases?
Old Jul 8, 2015 | 06:08 PM
jimbbski's Avatar
jimbbski
A carb that has sat for years will need to be removed and rebuild! Start there. IF you don't know how to do this try and find someone or a shop that can or see if you can buy a rebuild carb. They won't be cheap but you will get a good carb that will work.
Old Jul 15, 2015 | 09:48 AM
beartracks's Avatar
beartracks
Your floats might be stuck shut. You could try rapping on the fuel bowls to loosen up the needles and seats.
sdcowboy00
Nov 9, 2017 01:49 PM
katghoti
Nov 15, 2016 06:46 AM
benbuilder
15
Mar 4, 2016 05:26 AM
PatBethea
Dec 9, 2008 11:00 PM
cwtex
Dec 19, 2003 02:46 PM
