Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
VIN DECODER SHOWS NO INFO. AVAIL.
Old Jun 29, 2015 | 09:02 AM
iratepirate666's Avatar
iratepirate666
BIG FORD TRUCK gotta order a new radiator thought while i had it in hand id look up the vin num. (1FDNF60H0FVA18194). and no info available. any takers? replacing the gasoline engine with an older engine from a louisville cabbed truck and wont complete job until new replacement radiator enroute to my jobsite. all the info i can collect will benefit me in the long run.
thanks in advance for your time
Dennis
Old Jun 30, 2015 | 06:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Talking VIN decoded in less than 2 minutes!
Originally Posted by iratepirate666
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
N = Class 6 - Hydraulic Brakes - 19,501-26,000 lbs. Gross Vehicle Weight Rating.
F60 = F600 2WD (gas).
H = 370 2V or 4V.
0 = Check digit, FoMoCo use only.
F = 1985.
V = Kentucky Truck Assembly Plant.
A18194 = 1985 Numerical Sequence of Assembly, the trucks specific serial number.
faxonautolit.com located in Riverside CA has original owners/shop manuals, sales brochures, wiring/vacuum diagrams.
1980/89 Ford 600/900 (Heavy) Truck Parts Catalog available on a C/D from hipoparts.com ~ I just used this C/D to decode your VIN
I also have this catalog on Ford microfiche slides, but staring at scratchy microfiche w/the viewer located on the other side of the room, woulda taken longer than 2 minutes.
Old Jul 2, 2015 | 06:27 PM
iratepirate666
thank you very much. appreciate that you took your time and replied.
Dennis
apfeifer11
Large Truck
Jul 20, 2020 07:46 PM
hello113
Nov 19, 2017 02:58 PM
HOUCHIE
May 5, 2017 07:21 AM
rodeojunky
17
Aug 31, 2010 11:10 PM
