390 install cost (have 360)?
Cost? It all depends on who you want to do it. It is a simple direct swap, so it would take more time to remove hood then put new motor in. If you had access to crane, a few simple tools and an afternoon you could do it yourself. 16 exhaust bolts, couple radiator hoses, some wires, 6 bellhousing bolts(plus clutch/convertor bolts) and two motor mounts.
Valve jobs are not cheap anymore either. Depending on how many pieces need replaced. Simple grind job, degrease and re-assembly will set you back probably $200+/-. If you have real problems, the cost will jump considerably.
Larry
Larry
steve33444
106
11-30-2020 10:37 AM
71LTD390
04-17-2004 10:33 AM
ford390gashog
01-03-2004 12:46 PM
pward76
21
11-21-2003 03:35 PM
eclectix
17
08-20-2003 08:43 PM
