E4OD Interchangibility
Old Jun 28, 2015 | 05:54 PM
SIC-E's Avatar
SIC-E
Will the E4OD in my 1994 E250 work in a 2000 with an E4OD? Thanks in advance for the help.
Old Jun 28, 2015 | 09:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, it will not. The last year for the E4OD was 1998. The 2000 has a 4R100, and an E4OD will not work in place of a 4R100.
Old Sep 2, 2022 | 10:12 PM
cyanide's Avatar
cyanide
Would the e4od swap in place of the 4r100 if you used a non pwm converter and swapped the s pack out and changed the connector body side. Or would it involve a valve body swap?
Old Sep 3, 2022 | 12:46 AM
Conanski's Avatar
Conanski
No because it it won't even bolt up to whatever engine is in the 2000.
Old Sep 3, 2022 | 08:57 AM
Mark Kovalsky
You'll need to change a few more parts. The 4R100 has two speed sensors that the PCM requires or it isn't going to shift. To install those you'll need to swap the E4OD case for a 4R100 case and also swap the internals to get the speed sensor tone wheels.
Old Feb 5, 2023 | 12:46 PM
Hit Man X's Avatar
Hit Man X
Please delete, replied in wrong spot.
maverick1701
Sep 12, 2017 11:43 AM
RRE101
Jun 14, 2010 07:57 PM
