quick bolt question
Old Jun 26, 2015 | 12:33 PM
oughtsixbigred's Avatar
oughtsixbigred
quick bolt question
So I almost have my 6.0 egr/oil (and everything else needed) replacement done and I left the two bolts that go into the radiator fan shroud on the table last night which are missing!! The damn raccoons took them. I need to know what size are they? any help is appreciated.
Old Jun 26, 2015 | 12:41 PM
KDAVID1's Avatar
KDAVID1
quick bolt question
Are the talking the two that puts the stator to the intake?
The head is 13 or 15mm
Can't remember which now.
Old Jun 26, 2015 | 01:57 PM
dannyboy950's Avatar
dannyboy950
15 mm for the stator the black open frame work behind the fan blade.
Or are you talking about the flat plastic plate getween the radiator and front grill or the round plastic thing that guards the fan blade from the front? Those should be 8mm or 10mm and some push pins on the radiator side of the flat plastic piece.
Old Jun 26, 2015 | 02:03 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
If you meant the fan stator bolts that go into the intake, go under and remove one of the lower two stator bolts. They have a 15mm head, and all four in the stator should be identical.
If you mean the actual fan shroud to radiator, the four radiator support bracket bolts are identical to the two that go through the shroud.
Old Jun 26, 2015 | 02:15 PM
oughtsixbigred
I was not very clear, the two that go into the intake that bolt the shroud to it, I will do what texastech_diesel said...<table width="100%" align="center" class="tborder" style="border-top-width: 0px;" border="0" cellspacing="1" cellpadding="6"><tbody><tr title="Post 15460331" valign="top"><td width="125" align="center" class="alt2"></td><td class="alt1"> If you meant he fan stator bolts that go into the intake, go under and remove one of the lower two stator bolts. They have a 15mm head, and all four in the stator should be identical.
Thanks
</td></tr></tbody></table>
Old Jun 27, 2015 | 04:40 AM
Yahiko's Avatar
Yahiko
Get some liquid cayenne pepper and some nice sparkly
nuts and bolts.Dip them in the juice and let dry. Leave
out where your guests can grab then and watch the fun.
You might also try some dog kibble treated the same.
Sean
joezzz
Aug 9, 2018 04:48 PM
Mother_Love
1978 - 1996 Big Bronco
27
Jun 19, 2013 06:17 AM
Mannella9
Mar 20, 2012 01:48 PM
b4hntn
Jun 22, 2005 11:29 AM
jmooremtb
Apr 12, 2004 01:39 PM
