Suspension Upgrade
Old Jun 25, 2015 | 09:49 PM
Hellbringer's Avatar
Hellbringer
Suspension Upgrade
Hi
I have a 2007 F350 XLT 2WD that needs the suspension rebuilt. My truck currently looks a lot like the truck in the first picture (white one) and i want to rebuild the suspension but have it the height of the FX4 F350 a lot like the second picture (charcoal gray?? one) What is required in order to change the height to the FX4 height. I am not looking to do a aftermarket lift i am looking to use OEM ford parts.
Thanks
Mike
Old Jun 25, 2015 | 10:46 PM
mhoefer's Avatar
mhoefer
Going to be difficult if you are wanting to lift a 2 wheel drive the height of a four wheel drive. Coil springs fro snow plow prep package but I don't know if they will fit right in the front as they are meant for the 4*4. Y might try new springs from ford and lift pucks, perhaps a lift company has them, like Pro-Comp suspension.
Old Jun 26, 2015 | 08:26 AM
Misky6.0's Avatar
Misky6.0
You won't gain much upgrading the front coil springs... I gained < 1" on my Excursion which had stock 4400 lb springs, your F350 probably already has 4850 front axle gawr - so you likely are just wasting your time upgrading stock springs.
Here's my build, it's super easy to replace the 2wd coils, but you'll need something else to see any lift..
https://www.ford-trucks.com/forums/1...50-y-code.html
The 2wd twin I-beam doesn't allow small lifts, folks who get the 2" spring spaces OFTEN have issues getting an alignment because the ball joint and steering arm get in the way of being able to adjust the camber and caster enough - some folks have even ground down the parts to make a tad bit more room...
You really only have 2 options:
1) 4" 2WD lift kits (minimum amount to get the front end geometry correct)
2) Find a wrecked 05-07 4WD (it'll have front coil springs! vs. leafs from 00-04) and swap the transfer case and front suspension into your truck.
The 4" 2WD lift only puts you pretty close to the stock 4x4 ride height
There IS a few threads (perhaps in the Excursion forum) of doing #2 and it's on my wish list - someday, since I've got too much invested in my 2wd Excursion.
Old Jun 26, 2015 | 10:26 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Leveling kit install:
https://www.ford-trucks.com/forums/1...kit-is-on.html
Lift:
http://www.fabtechmotorsports.com/FO...sel-p1073.html
jmuenchow
Apr 4, 2017 11:31 PM
nanrulz
13
Feb 7, 2009 11:26 PM
a2b
Jul 23, 2004 04:43 AM
Rcmgiasson
Offroad & 4x4
Sep 28, 2003 11:15 PM
Neil
1978 - 1996 Big Bronco
Nov 19, 1999 03:28 AM
