3.0 l. misfire
Old 06-25-2015, 01:15 PM
widdie's Avatar
widdie
widdie is offline
3.0 l. misfire
howdy, new member but long time observer
2001 ranger edge 2wd with misfire issue - misfires occur under power, not at idle - replaced plugs (mc dbl plat) and plug wires and new oem coil pack
any ideas to narrow down my search?
thanks
Old 06-25-2015, 04:31 PM
Dan Robertson's Avatar
Dan Robertson
Dan Robertson is offline
My 98 ended up needing a fuel injector.
Old 06-27-2015, 03:04 PM
widdie's Avatar
widdie
widdie is offline
Thanks Dan
I guess I have to determine which cylinder is the problem and then go to the injector. I'm getting over 21 mpg and there is no loss of oil between changes so I guess the injector is next.
Thanks again
Ford strong for me
Old 06-27-2015, 06:44 PM
mfp4073's Avatar
mfp4073
mfp4073 is offline
I would just about do anything for 21mpg in my 3.0. Let me ask you to describe your misfire? Is it from a code by sound?
Old 06-28-2015, 10:26 PM
Tennesseepowerstroke's Avatar
Tennesseepowerstroke is offline
On my 04 it was the PCM. I determined this after replacing the plugs and coil pack.
Old 07-07-2015, 07:48 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Welcome to FTE.
Use your ELM, scantool, code reader, to look for engine computer trouble codes & post All code Number clues. If you don't have one, most autoparts stores will scan for codes at no charge if your CEL is on, or flashing, some will scan if your having problems without a lit CEL.
Why did you replace the plugs, wires & coilpack??? Was it plug & wire replacement time, or did they test bad????
On the old plugs, did you do a plug deposit "read" & if so, did any plug/s look different & if so, how did it look different, as that info can offer up clues on how that cyl was behaving.
As has been suggested, a number of things can cause engine misfire, spark plugs, wires, coilpack, fuel injectors, sticking or burned valves are some that come to mind.
If you don't have any trouble codes stored, but have, or can come by a scantool like the Actron CP9145, ect, that can perform a cyl balance test, that test could suggest which cyl/s has a problem. If no joy on the cyl balance test, hook up the scantool & go for a drive that'll cause it to misfire & the tool should store that info clue in memory that you can access after your test drive.
Under load misfire is usually spark related, like excessive plug gap, cracked internal/external ceramic insulator, plug wire insulation, contact, or conductor problems.
Just because the plugs, wires & coilpack are new doesn't automatically make them good, make them prove themselves by testing. Maybe consider a "wet down test" with a spray bottle of water at night with the engine at warm idle. Wet each plug, plug wire all the way back to the coilpack, then the coilpack, looking for a arcs & sparks light show.
More trouble shooting thoughts for consideration, let us know what you find.
Old 07-12-2015, 02:32 PM
e30vandy's Avatar
e30vandy
e30vandy is offline
Was it misfiring before replacing plugs and wires?
erpshouse
2004 - 2008 F150
01-18-2011 06:47 PM
73effie
08-16-2009 12:27 AM
D.I.L.L.I.G.A.S.DAVE
3.0L V6
05-25-2009 12:13 AM
02f250fx4
Modular V8 (4.6L, 5.4L)
08-21-2007 04:06 PM
strokin72
1997-2006 Expedition & Navigator
02-28-2006 04:41 PM
Quick Reply: 3.0 l. misfire
