352 engine question
Old Jun 24, 2015 | 03:19 PM
brbuchanan's Avatar
brbuchanan
352 engine question
Changing the intake on the 352 F100. Do you need to keep any kind of order
to the way they came out if you are replacing the lifters and the pushrods with all new ones. I know if you are using the same parts to go back in it to keep them in order with the way they came out. But all new parts?
Thanks
Bobby
Old Jun 24, 2015 | 05:01 PM
bphirt1's Avatar
bphirt1
352 engine question
Thanks
Bobby
Hello. Just replaced my lifters and pushrods on my 66 352. There is no order to install them. Make sure all pushrods are same length as the ones you pull out and follow torque specs for rocker shaft and intake.
Old Jul 4, 2015 | 12:01 AM
Oldschool2888's Avatar
Oldschool2888
you may want to check the length on the push rods as there are several lengths. as the heads were milled over time longer push rods were needed to compensate.
usuallybowtie
Mar 18, 2014 05:51 PM
angel.aprilia
Jul 7, 2008 05:10 PM
buckrogers
20
Jul 12, 2007 03:17 AM
66flareside
Mar 8, 2006 10:25 AM
69SWB
Oct 20, 2001 09:30 PM
