1978 or 1979
Old Jun 25, 2015 | 01:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by karjunkie
Is this even my sticky, lol, so what I'm reading is that there is no real way to tell if its a 78 or 79 frame, from a visual standpoint
Outer right (passenger) side frame rail towards the front of the truck, has an frame ID engineering number stamped on it.
1978 ID number prefix (D8TA) is different than 1979 ID number prefix (D9TA).
But, you haven't mentioned if the frame is for a 2WD or 4WD, for an F100 or F150 or F250 or F350.
All these frames are different due to what their "section modulus" (depth of the frame rails) is.
Old Jun 25, 2015 | 01:25 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's the frame ID number on a '73 2WD. Like ND said, outside RH side frame rail.
Old Jun 25, 2015 | 05:24 PM
karjunkie's Avatar
karjunkie
Sorry fo the lack of information, Lilly is a F250 4X4
Old Jun 25, 2015 | 05:48 PM
karjunkie's Avatar
karjunkie
I just cleaned 38" from the front of the frame toward the fenderwell exits and i dont see no stamp marks, that part of the frame did have alot of rust that could have been peeled with a fingernail so i believe it had rusted away
Old Jun 27, 2015 | 10:27 AM
SlikWillie's Avatar
SlikWillie
Do believe 1978 and 1979 F250 4x4 frames were the same. If you have a '74 cab, then your build will not be all original. Which in this case, who cares. Build your truck, be happy, post pictures.
Old Jun 27, 2015 | 12:51 PM
karjunkie's Avatar
karjunkie
Wish i cud post pictures here, i just like knowing what i have without playing the guessing game, with the frame in the condition its in i may not figure out what year it is, unless i pull the cab up to see if there are stampings on that part of the frame, wich i am not gona get in to atm, lol
Old Jun 28, 2015 | 12:27 AM
Jdeshler's Avatar
Jdeshler
You having troubles posting pictures?
Old Jun 28, 2015 | 06:38 AM
karjunkie's Avatar
karjunkie
Uploading a picture is not working
joel79ford
77
Apr 30, 2012 03:58 PM
Ford_Six
Sep 23, 2010 05:19 PM
kadrocker
Feb 26, 2010 09:24 PM
Mobat555
Aug 7, 2007 04:17 PM
OldSchoolRodz
Jul 17, 2004 03:12 AM
