2004 ranger
Old Jun 22, 2015 | 04:30 PM
allplotts's Avatar
allplotts
2004 ranger
it has the 4.0L V6 is this motor called a triton? a local motor rebuilder lists both a ford 4.0L and a Triton 4.0L? how do i figure what i have for a motor?
Old Jun 23, 2015 | 08:29 AM
exranger06's Avatar
exranger06
I have no idea where your rebuilder gets his information. There is no such thing as a Triton 4.0L. The only 4.0L available in 2004 was the SOHC (single overhead cam) 4.0L. There used to be a pushrod 4.0, colloquially referred to as the OHV 4.0, but that engine was discontinued in 2000.
Old Jun 23, 2015 | 05:46 PM
allplotts's Avatar
allplotts
thank you very much
Old Jun 24, 2015 | 04:26 AM
allplotts's Avatar
allplotts
i check with the engine guy he is calling the SOHC motor the triton and the other one is the OHV motor. now my question is what is the differences? the motor cost difference is about 1000. would this other motor work i am just trying to make a hunting truck?
Old Jun 24, 2015 | 07:43 AM
exranger06's Avatar
exranger06
The 4.0 OHV will drop in and bolt up to your existing transmission, but you'd have to deal with all different accessories and brackets, wiring, air intake, etc. You'd probably spend more than $1,000 in additional labor and buying all the stuff to make it work, and you'd end up with an engine that has about 50 less HP than what you had before. Just get the correct engine and drop it in.
Old Jun 24, 2015 | 06:35 PM
allplotts's Avatar
allplotts
thanks again very good advice i will follow
Old Jun 24, 2015 | 06:51 PM
Rich7944's Avatar
Rich7944
If your mechanic is recommending installing the OHV vs the SOHC motor then I would find another mechanic. So not worth the trouble.
Ranger20001
General Automotive Discussion
Sep 9, 2017 08:45 AM
nossliw
Apr 24, 2012 08:07 PM
JF5speed
1997 - 2003 F150
Jan 23, 2005 08:17 PM
wesman19
Oct 16, 2002 08:24 AM
