Is there an option to buy the whole sway bar set-up as a kit? Or link and bushings?
If not, are there any aftermarket options? Check with RV dealers, this was once the only choice prior to FoMoCo offering them.
I'm just trying to fix to pass state inspection.
Ford never sold a kit, each part had to be bought by itself.
D8TZ-5A486-A (replaced D3TZ-5A486-A & E0TZ-5A486-A) .. Front & Rear Stabilizer (sway) Bar End (link) Bushing Kit / Available from Ford & auto parts stores.
Yep, 5K484. I don't see any that fit in the links provided. Unlike the picture, there is a bend in the link and it's not a straight piece. Thanks for the suggestions.
I already took it to a shop and it didn't pass because of the end links. So they already know that I have it on the truck. He told me if i just replace them then he would pass it and i wouldn't have to pay again. I would like to fix it and keep it with the sway bar too.
So let me get this straight, you HAVE the sway bar links and just need the bushings? Or the sway bar links you have are damaged or for some reason the place will not pass it?
