1994 A/C issue
Old Jun 21, 2015 | 09:00 AM
edo488's Avatar
edo488
1994 A/C issue
1994 F150, 5.8, 2wd, TEXAS
Has not been as cold as I thought is should be and is would quit blowing cold air occasionally when on Max A/C. If I turned it to regular A/C or lowered fan speed the cold air would return. Had it serviced and they replaced a hose, orifice, A/C manifold, and recharged. Much colder now but still get the occasional stoppage of air flow.
Old Jun 21, 2015 | 09:25 AM
Sdowdle541's Avatar
Sdowdle541
Is it diverting to the defrost when on max AC and then going back through the front vents?
Old Jun 21, 2015 | 09:47 AM
edo488's Avatar
edo488
not sure but airflow from vents stops. I will check today and find out. If it does, what does that indicate?
Thanks for your input
Old Jun 22, 2015 | 03:45 PM
tjc transport's Avatar
tjc transport
i ain't rite
air diverting to defroster ducts is a sign of a vacuum leak.
Old Jun 23, 2015 | 07:53 PM
edo488's Avatar
edo488
air is being diverted to the defroster for a few seconds then it diverts to floor/heater vents. If this is an indication of vacuum leak what is the best way to track it down. Probably the original vacuum lines. Would it be easier to just change them all out and the check valve?
Old Jun 23, 2015 | 08:34 PM
White 97 xlt's Avatar
White 97 xlt
The first one to check when this happens, is the white vacuum line right on top of the A/C box under the hood....
Diverting to the defrost position for air flow is a safety measure, to keep the windows clear in cold weather even if there is a problem.. It's all about seeing!!!
Old Jul 5, 2015 | 07:32 AM
edo488's Avatar
edo488
thanks white97xlt. White vacuum tube is disintegrating. What is the best way to fix this? I hope the line inside the plastic cover leading to firewall is not in bad shape. If it is in good condition can I just splice it? Looks like I need pull it out of the protective wrap and look for a good section to connect to. Can I just cut it and use a larger diameter line to slide over the white line?
Old Jul 5, 2015 | 07:50 AM
tjc transport
i ain't rite
i have done that before with success.
Davis & Sons
Apr 23, 2009 09:06 PM
mrgn_mtt
Jul 23, 2008 09:32 PM
philmo418
May 24, 2008 11:43 PM
Jaymey
Jul 23, 2004 02:50 PM
chocolate moose
Jul 16, 2002 09:36 PM
