Transmigration question.
Old Jun 21, 2015 | 06:47 AM
GM4WALLS's Avatar
GM4WALLS
When it comes to transmissions, I am am idiot. I currently have three running and driving Dents. All have the C6, one behind a 360, one behind a 302 (have to double check could be a C4), one behind a 300.
All three trucks seem to shift to second really early and third around 30 MPH. So by the time I hit 55-60, the engine is turning pretty high RPMs. Obviously an OD transmission or a manual with more gears makes sense to fix it, but is there a way to adjust the shift points on the three speeds?
Old Jun 21, 2015 | 08:00 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes there is. But that's not going to make any difference in the RPM at 55-60. You still will only have three speeds.
Old Jun 21, 2015 | 08:25 AM
GM4WALLS's Avatar
GM4WALLS
I understand that, but I am going all of 10 miles an hour when it shifts into second.
Old Jun 21, 2015 | 08:27 AM
ultraranger's Avatar
ultraranger
More gears only spreads the gear ratios out of the transmission.
A C-4, C-6 or any non-overdriven transmission is going to be 1:1 in high gear.
An overdrive transmission, standard or automatic, is typically 2/3rd overdriven. --usually ~.67:1 (but can vary).
Final drive equivalent for the vehicle will be whatever the rear end ratio is, multiplied by the high gear (or overdrive) ratio of the transmission.
A C-6 has a 1:1 ratio in 3rd. If you had 3.50 gears with a C-6, you would multiply 3rd gear by the rear end ratio.
1:1 x 3.50:1 = 3.50:1.
If you had an overdrive transmission that had a .67:1 overdrive ratio, you would multiply that by the rear end ratio to get the final drive equivalent.
.67:1 x 3.50:1 = 2.35:1.
In overdrive, the final drive equivalent would be as if the rear end had 2.35:1 gears. This would produce far less RPMs at highway speeds.
Old Jun 21, 2015 | 08:33 AM
GM4WALLS's Avatar
GM4WALLS
So my best options are a rear gear change or an OD tranny?
Old Jun 21, 2015 | 09:03 AM
ultraranger
If you change rear end gears but keep the current transmission, you'll have to decide what the truck will primarily be used most for, before choosing a rear end ratio.
If you want highway mileage, you'll have to go higher (lower numerically) with the rear end ratio. This will give decent mileage and lower cruising RPMs but, towing/pulling and acceleration ability is going to suffer.
If the truck will primarily be used to pull/haul heavy loads, you'll have to go lower (higher numerically) with the rear end ratio. This will be good for pulling and for acceleration but, it'll be bad for fuel mileage and cruising RPMs on the highway will be high.
If you had an overdrive though, you could have lower rear end gears (higher numerically) that will be good for pulling or acceleration and you would be able to get decent highway mileage with much lower cruising RPMs. --an overdrive would give you the best of BOTH worlds.
Old Jun 21, 2015 | 09:16 AM
GM4WALLS's Avatar
GM4WALLS
I read on another thread about the 4R70W needing a stand alone shift module. Any input on this tranny and where I could find the module for sale?
Old Jun 21, 2015 | 09:28 AM
Mark Kovalsky
The vacuum modulator (where the vacuum line attaches to the transmission) has a screw that will adjust the shift speeds.
Old Jun 21, 2015 | 09:32 AM
GM4WALLS's Avatar
GM4WALLS
Thank you.
Old Jun 21, 2015 | 09:37 AM
ultraranger
My 4R70W isn't installed in my truck, yet, due to the fact that I have to rebuild the transmission but, it's also because I have a 5.0L EFI engine from a '90 Mustang GT that has to be gone through before that, until they can both be put in my truck.
I pulled my 4R70W from a 3.8L '98 Mustang. The 4R70W came out in 1993 but, the best models of this transmission were from 1998-2004.
I bought my shift controller from this company.
The US Shift Transmission Control System
Good information on this transmission, written by one of the Ford transmission engineers that designed it.
TCCoA Tech Articles
If you're thinking about running one of these transmissions, my best suggestion is to do a web search and read/study all the information on it you can find, to learn all you can and to be informed about it, before going out and buying one.
Old Jun 21, 2015 | 09:41 AM
GM4WALLS's Avatar
GM4WALLS
TCCoA Tech Articles
I appreciate the link. Thanks for the help.
Old Jun 21, 2015 | 09:46 AM
beartracks's Avatar
beartracks
To adjust the shift point on a C6 you adjust the kick down rod at the carb. I think the "normal" setting is .015 slack between the lever and the rod.
Old Jun 21, 2015 | 09:48 AM
GM4WALLS's Avatar
GM4WALLS
Any how to articles?
Old Jun 21, 2015 | 12:03 PM
cr500monster's Avatar
cr500monster
i had one rebuilt that shifted way early , drove it like that for a while till i broke the trans had the same guy rebuild it told him it wasnt right ban when i got it back it shifted right he said it was out of adjustment a it worked as it should till i sold it
1969ecarrell
Feb 15, 2015 05:28 PM
turboman24
13
Nov 3, 2007 02:49 AM
enoree
May 22, 2006 12:28 PM
Gunslinger
Mar 16, 2004 03:21 PM
ivanribic
Dec 12, 2003 08:29 AM
