Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Brakes.....NEED HELP!!!
Old Jun 20, 2015 | 10:32 PM
F600Logger's Avatar
F600Logger
Ok, this weekend I finally decided to unlock the rear brakes on my 1968 F600 I had everything out, axels, bearings etc..., the brake drums are rusted shut, I got one brake drum off by unbolting entire drum from rear-end. It is an Eaton 15201 rear-end can I get new brake drums? or should I just find a completely new rear-end? If I need a new rear-end, what rear-end should I get? I'm beyond frustrated.
Old Jun 21, 2015 | 05:05 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Where are you located? If your anywhere near Seattle give Brake and Clutch Supply a call, Brake & Clutch Supply
Or if you don't want to mess with it you can get an entire rear axle from a later model, frame widths stayed the same for years.
Sam
Steve in NC
Jan 10, 2017 08:03 PM
One Sock
Jul 25, 2016 10:15 AM
ZachManXLT
1997 - 2003 F150
May 1, 2016 02:17 PM
48fordf3
May 18, 2005 10:47 PM
