'84 F700 starting/idling trouble
370 V8 4bbl carb truck always started well but after stalling it on an incline in my driveway I hit the brakes to keep it from rolling back and it jerked a little. After that, it didn't want to start. I gave it new plugs, cap, and rotor - the wires look good. It started - barely - but still ran like **** and doesn't want to idle much below 1000 rpm. I drained out all the gas and rebuilt the carb that was cleaner inside than any carb I've ever opened up before. The spark on a pulled plug was white but could be bigger and brighter. I was thinking about reattaching the coil connectors. It has the one piece collar that slips on. Do those terminals come out? Anyone have any ideas? Thanks.
So the stalling incident--did that cause the engine to reverse rotation even a little bit? Rolling backwards in a forward gear is what I'm suggesting.
If so, maybe, just maybe you have a timing chain issue. Pull the distributor cap. Rotate the engine with a wrench. Reverse rotation and see how many degrees of crank rotation you get before the rotor moves. Much over 5 degrees means it's time to think about replacement. A lot more could allow the chain to jump a tooth, which will cause the problems you describe.
Just a wag.....good luck with it.
80' ford man55
07-31-2014 08:39 PM
ndmccann
10-08-2012 01:11 PM
Tattyjoe
07-28-2012 04:36 PM
acerocks666
08-16-2010 06:20 PM
76fordexplorer
05-20-2009 04:13 PM
