Steering UJ
Old Jun 19, 2015 | 09:17 PM
Troubleuk's Avatar
Troubleuk
Steering UJ
Hi
Need a little help identifying the power steering box and sourcing some kind of UJ to go between the box and column.
The box I think has 30 splines on it.
Also the what I would call the lower steering column bush/bearing is totally ruined.
Its my first older pick up but the steering didn't seem to self centre at all just stayed where you put it with about 3 inch of play left/right on the wheel.
any help is greatly appreciated.
Old Jun 20, 2015 | 09:57 AM
Roger Carter's Avatar
Roger Carter
Chevy and GMC used out board mount PS boxes. That might be a place to start looking.
Old Jun 20, 2015 | 10:22 AM
resonateur's Avatar
resonateur
Go to the Borgeson website. They have a variety of u-joint styles, adapters and shafts. They should be able to advise you on what you need.
Old Jun 26, 2015 | 05:36 PM
svolpone's Avatar
svolpone
Heights u-joints are good. I got mine from Summit Racing. I bet you have 36 splines, though. I'd count again.
Old Jun 26, 2015 | 06:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Your "About Me" profile says 1966 F100, but is it 2WD or 4WD?
If it's 4WD, P/S wasn't available until 1973 and then it was Power Assist P/S thru 1975.
1966 F100 4WD, 1967/75 F100/250 4WD's use a multi-part lower steering shaft & coupler that includes a u-joint.
But what you appear to have, is a butchered one piece lower steering shaft and coupler assy from a 1976/79 4WD
Look on the gear box sector shaft cover for a cast ID number, post what it is.
Old Jun 26, 2015 | 08:49 PM
Troubleuk's Avatar
Troubleuk
thanks for the replies guys.
The steering box end is 30 spline 3/4 and the column end is 36 spline 3/4 so I have ordered 2 x Joint to suit with 3/4 DD shaft between .
I know its not original but the frame has been cut and welded so kinda stuck with it for now.
Butchered isn't the word that thing could have killed me tbh.
Can anybody identify what the box is incase I need to replace it, just had a look in the dark and the number thats stamped on like a square raised part is 6A232 if that helps?
leardvr
Apr 19, 2015 12:44 PM
Fordrat
Sep 13, 2012 04:00 PM
Junkman of Delaware
Dec 28, 2011 09:29 PM
hivolt5.0
Feb 21, 2009 03:29 AM
frogmun's 55
Apr 9, 2007 09:11 AM
