Understanding payload on F-250 6.7L
I read those PDF's for 2011 through 2013 that list the maximum tow and maximum payload, they break them out with all the F-Series SRW, DRW, 4x2, 4x4, etc.
I see that for example it shows 2011 F-250 4x4 SRW 156.2" will have a 3250lbs max payload. Then I go to the dealer and see a 2011 F-250 Lariat, 6.7L Diesel, 4x4, SRW there and the sticker shows max payload of 2065lbs. I guess I can understand that the PDF spec was based on an XL, 4x4, SRW, Diesel, 156.2" with no add-ons. But can that really account for 1185lbs of stuff? What gives?
How do some people say they have F-250 SRW Lariat or XLT or nicely equipped stuff with 2500-2600 payloads. I would imagine they are almost all the same, it's not like one built somewhere else has an extra left spring or something, right? Also is this 2065lbs on the sticker expecting a full tank (not even sure of the size now) plus a driver (example: 150lbs + 20lbs personal stuff) THEN of coruse you add all your extra payload?
Forget the stickers and the books. GVWR minus the trucks weight on a scale ticket. then RGAWR minus rear axle weight on the scale ticket is the answer. It varies between each and every truck depending on what that owner considers their basic "no load' load.
I usually get the feeling that people who argue about the book towing and hauling specs don't actually have weight tickets on their trucks. Post a ticket and then I'll believe the numbers they post, until then it's all theoretical.
I have 1520# payload based on this ticket. GVWR - weight; 9800# less 8280 actual = 1520#. RGAWR - weight; 6100# less 3440 = 2660#, meaning GVWR limits me before the axle weights. It's probably more like 1800# payload in the real world depending on where the weight is, in the cab, in the bed, or on the drawbar, but hard numbers says 1520# until weighed otherwise.
This is the 2011 Source book (yoiu can google: Ford Super Duty 20XX Source Book" to find it for any year):
https://www.fleet.ford.com/truckBBAS...Pickups_SB.pdf
Page 80 lays out all the rear spring pack configurations.
Page 61 in this .pdf is more realistic than the slimmed down promotional material guides, but still need a real weight ticket to plug in actual front/rear/gross weights to be entirely sure.
https://www.fleet.ford.com/truckbbas...ckup_specs.pdf
It would be nice to have the 350 for the "just in case I need it factor", but the extra costs just are not worth it for me.
rcklnhunter
6.7L Power Stroke Diesel
42
03-28-2022 08:35 AM
Tnriverside
1999 to 2016 Super Duty
19
09-16-2015 10:13 AM
Milwaukee1979F150
01-10-2011 08:02 AM
bgodkin
02-13-2001 08:45 PM
