Sponsored by: Real Truck
cheap lift
Old Jun 17, 2015 | 06:28 AM
06whiterhino's Avatar
06whiterhino
cheap lift
i have a 06 f250 and am looking fora cheap way to lift it i was told that if i take the coils and leafs out of a 350 and put them in ill get around 5in of lift like you would by putting 350 springs in an excurison I'm just trying to validated this information
Old Jun 17, 2015 | 06:35 AM
Bently_Coop's Avatar
Bently_Coop
You can use a F350 block in the rear. Which will give about 2" in the rear. Use the thread below for part numbers.
https://www.ford-trucks.com/forums/6...ar-blocks.html
For the front it depends on which coils you currently have. Is your truck a 2WD or 4WD? The spring with most lift from factory will be a plow prep spring. For 99-04 they are called a X code, and you can identify which you have by looking over the sticker on the inside of your door frame.
5" on factory parts is not going to happen though.
Old Jun 17, 2015 | 09:39 AM
speakerfritz's Avatar
speakerfritz
maybe a body lift would be better?
Old Jun 17, 2015 | 11:57 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
False, there's no way to get 5" of lift with stock coils and rear springs in a 2006. Depending on the F350 you take the springs from and the F250 you add them too, you might actually be swapping identical components.
The most you could gain from the lowest gas F250 4x4 to the highest diesel F350 4x4 in 2006 is 4000# coils to 6000# coils up front, and the addition of an auxiliary spring in the rear leaf pack. To get that, you'd have to find an F350 with the heavy service suspension, camper, or snow plow prep packages, and your F250 would have to be a 5.4L, probably a regular cab long bed XL with zero upgrade packages. Check the VIN sticker on your A-Pillar below the driver's door latch, if your FGAWR is 4800# or higher, even swaping in 6000# coils will net maybe 1" in height, in exchange for a harsher ride. If you swap in from pre-2005 you'll be donwgrading, and post-2008 the leaves are longer and won't fit without replacing the spring hangers.
To get 2" in the front, you can use an upper or lower spacer, Then in the rear you can get 2" in the back with a rear suspension spacer swa:
https://www.ford-trucks.com/forums/9...installed.html
Rear only with P/Ns:
With reference to the Excursion, are you talking about people buying X-code front springs, and then adding in leaves to the existing packs? It won't do you any good to add in leaves from an F350 in the rear, you'll already have an identical main pack anyways. You'd have to find an actual add-a-leaf package that fits in between two existing leaves without being the identical length.
You can't add 5 inches to the front of a 2006 without either relocating the radius arms or putting in longer ones, it's simple geometry in the suspension and steering and it just plain won't work.
See page 31 for spring information:
https://www.fleet.ford.com/TRUCKBBAS...essd-ms_06.pdf
Old Jun 17, 2015 | 02:00 PM
Xcursion88's Avatar
Xcursion88
No.
No way.
No how.
5" lift by swapping to f350 springs no matter the 250 springs you have will not get you 5 inches.
Moreover the suspension makeup on these vehicles being solid axle is simple. There is not much to lifting them therefore not many components therefore not very expensive. Ha ha.
I'm sure you can get some lift front coils and then get creative to lift the back using add a leaf or block or both.
But there is no ultra cheap answer for your quest.
Good luck.
Old Jun 18, 2015 | 05:21 PM
Kuhntech's Avatar
Kuhntech
Do it right, or you will be sorry!
Tires for these beasts aren't cheap.
Justforfishing
Sep 14, 2018 01:46 PM
nojoke327
Offroad & 4x4
Nov 29, 2013 06:01 PM
GotLift
Sep 13, 2005 03:28 PM
Chadwick122085
Sep 19, 2003 01:46 PM
kidshock
Bronco II
13
Sep 17, 2003 09:17 AM
