Downshift on uphill while towing
Question: while towing up long incline, engine got hot, shot message through dash saying truck would shift gears to ovoid overheating. I have read I should lock out 5 and 6 on slow steady climbs. If I am in tow mode and want to downshift, how do I do that? I know I can shift entire thing to 2nd gear - but I assume that is not what we are talking about here. On this particular climb it was hot (100 out) and I was blocked in left lane going slower than I would have liked. RPMs were low.
Detailed description of process would be great.
I also regularly use Tow/Haul. Sometimes on decline I will downshift to 2nd or 1st and not use brakes at all going down. Thoughts?
If you're in 'D' you should see the gear numbers either along the bottom of the center gauge area (on my STX work truck) or along the right hand side of the center LCD screen (my FX4). If you don't see any gear indication lit up, hit the + button once on the shifter and you should see it. Now, you can hit the - button once to remove 6th gear from the shift scheme. The transmission will act normally by up and down shifting as you drive, but you've locked out 6th gear. Hitting the - button again will lock out 5th gear so only 1 through 4 are available and so on.
I've always found the lowest temperatures to occur when you're in the highest gear possible. I haven't towed much long distance with an EcoBoost truck, so that may be a little different for this engine.
if you have a towing package then the truck comes with a feature called "select shift" this refers to the +/- rocker on the gear selector, and the "M" position on the gear indicator.
Select shift has two modes: manual shift and progressive shift (i'm paraphrasing).
in manual shift mode, with the gear selector in "M" the transmission will be locked into whatever gear the truck is currently in when you shift it into "M" and will not shift out of that gear until you press the rocker up(+) or down(-). the gear you are in will be displayed on your dash.
in progressive shift mode it will shift up and down normally, but you can lock out the upper gears (all the way down to first, iirc). to activate the progressive shift feature simply press the rocker up or down (+/-) while the gear indicator is in "D". this will illuminate a gear display on your cluster with the current gear being highlighted. to lock out gears, press the rocker down and you will see the gears progressively disappear from your display indicating that gear will no longer be used.
you can utilize either of these methods at any time to force the truck to downshift, if you feel the need to do so.
then there's the good'ole "forced downshift" by pressing the accelerator pedal to the floor. this will almost always cause the truck to downshift, but will likely cause an upshift when you let off, effectively not solving the problem you are trying to solve.
something else of note is that the transmission will respond differently to the vigor with which you press or release the accelerator, particularly in tow/haul mode. that is to say a slow squeeze on the skinny pedal is less likely to cause a downshift, whereas pressing it quickly will usually cause it to downshift, even though you pressed it the same amount. Likewise, the rate at which you lift will change the way the truck shifts as well. a slow lift will usually cause an upshift, but if you snap off the throttle it will usually hold the current gear to help you slow down (particularly in tow/haul).
as i said, this is all paraphrased from the owner's guide, but it would probably be a good idea to read through some of it if you get time. these trucks do so much more than the trucks even 10 years ago. the Powertrain Control Module controls both engine and transmission functions and utilizes them very much together as a tool to help the truck do what the driver is requesting.
hopefully that helps a little, though.
makes some sense to me. downshifting will increase engine speed which will increase coolant flow. particularly running at high boost, more coolant flow would seem advantageous, within reason, that is -- which is exactly what the truck did without being told to do so.
Putting the truck in tow/haul should run the transmission and engine harder, but it should also kick the transmission into a different cooling mode to help with the extra heat.
I personally have never seen an over-heating message on the screen before. That thing must have been working hard!
i don't know what that breakover point is, but i bet the PCM does. if i were to guess, i'd say it was in the lower 1/2 of the rpm band, but that's just a gut feeling.
Better thing to do is slow down and drop several gears to unload the engine. Make those gears do the work instead of the engine.
Trans cooling system is the same system either way. No magical stuff happening in tow/haul mode.
