390 Connecting Rods
Old Jun 16, 2015 | 02:24 PM
FordStolz68's Avatar
FordStolz68
390 Connecting Rods
Any thoughts (weight, durability, etc.) on using Eagle H beam Rods 64903F3D or Falconglobal OE Rods BP143 as I'm rebuilding my 360 to 390 specs. I'm sticking with 3.49 rod length. (Falconglobal are a lot less expensive and rebuilt OE)
I'm open to other MFG, just can't spent whole budget on these.
Truck is a daily driver that sees mild Desert play.
Old Jun 16, 2015 | 02:38 PM
307-Niner's Avatar
307-Niner
I used a set of the Eagle H beams in a 390 build. Decent rods, but there was significant weight difference between each rod in the box. Not a big deal really, you should have your rotating assembly balanced anyways. I have pics somewhere...
Old Jun 16, 2015 | 09:56 PM
HIO Silver's Avatar
HIO Silver
Depending on the planned RPM range and max RPM of your FE, high performance rods might not even be necessary.
Old Jun 16, 2015 | 10:27 PM
FordStolz68
Thanks guys, was just thinking if I could get a lighter rod(s) w/ possibly more strength @ a resonance cost might as well as its apart. Not going to get revved much as all the components for the build are going for torque. But still liked the idea of something a little lighter even if it may take away from inertia. But do like the lower cost of OE rebuilds.
Old Jun 16, 2015 | 11:01 PM
HIO Silver's Avatar
HIO Silver
I'd look into putting dollars into the workmanship and attention to detail like dead-nuts balancing the entire rotating assembly, ported heads, ARP hardware, and a really good machinist.
Here is a really good website for your reference: Ford FE Engines Max Performance Archives - DIY Ford
Old Jun 17, 2015 | 01:04 AM
FordStolz68
Good read,
thank you.
colnago
25
May 26, 2018 01:02 AM
Alvin in AZ
Apr 4, 2009 01:14 AM
joegeoghegan317
Aug 20, 2004 09:49 AM
montana70
Apr 15, 2004 12:12 PM
Freakazoid!
Mar 1, 2004 06:45 AM
