Does anyone have an extra set of rear shackle brackets for a 1950 F-1. They are part number 21C-5775. I've tried Macsauto, Midwest and C&G any they're all out of stock as well as a few other places it seems.
If anyone knows where I could find a pair I would appreciate it greatly.
Thanks,
If the 52s are the same I tossed mine in the trash a couple days ago. I can pull them out if you can use them. I have all the pieces, what do you need?
Hey, the 52's will fit. The part I need looks like the one on this site.
I checked the trash and they were the front ones. The rears I removed at work so I could ship the springs to a member. Tossed the a couple months back, sorry.
Hey guys!
Im looking for a set of the rear shackles also.
Plus does anyone know how to the rebuild the leaf spring packs,bushings etc?
Thanks
Are you looking for the shackles or the frame mounts? I have one set of the frame brackets and the shackles as well. I sold a pair of the frame brackets. Email me if you still need them and specifically what you need.
1942/47 Commercial (1/2 ton truck) / 1948/52 F1.
21C-5775-A (replaced 21C-5775) .. R/L Rear Spring REAR Hanger Bracket / Rivets to frame rails / Obsolete
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 8 = 800-476-9653.
21C-5775 =
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
------------------------------------------------------------------ 21C-5776 .. R/L Rear Spring REAR Shackle Bracket / Nestles into hanger bracket / Obsolete
NOS PARTS SOURCE has 1.
4) 21C-5791-A .. Rear Spring REAR Bushing (2 per side), fits into shackle bracket. Also 1953/56 F100 / Obsolete
2) 21C-5780 .. Rear Spring REAR Shackle Pin. Also 1953/56 F100 / Obsolete
Pin fits thru outside of hanger bracket-thru shackle bracket-then into the inside of the hanger bracket where it rivets to frame rail.
Phil
Hey Phil!
I'm looking for the four frame mounts (shackle hangers).
Ive got everything but the frame mounts,and 1 pin...does anyone have a diagram on how to reinstall rear leaf springs?
Thanks.
Hey Phil!
Thanks.
Send me a PM with your phone number if you want the two frame mounts that I have for sale. I also have two spring shackles, still.
The Ford Illustrated Parts Catalog has a diagram on Page 129 showing the Model C & D diagram which shows the rear spring assembly. This is a "typical" drawing so it is not exactly the same. The part no. "5335 or 5337" on the earlier models (48-50) is actually the frame bracket no. 5775 shown on page 111 of the Model C frame. The two frame brackets I have are the 5775 part no.
NumberDummy,
Ooops! My bad. You are correct. I was in a hurry when I posted the reply and my over 40 mind struck me stupid when I read "front". It told me I was reading rear. My reproduction parts catalog is hard copy so I can't insert illustrations.
Thank you so much for the well deserved correction. Age does horrible things to your brain. My advice is don't get old.
NumberDummy,
Ooops! My bad. You are correct. I was in a hurry when I posted the reply and my over 40 mind struck me stupid when I read "front." It told me I was reading rear. My reproduction parts catalog is hard copy so I can't insert illustrations.
I know all about getting old, as I'll be 71 in September.
1948/56 Ford Truck Parts Catalog available on a C/D from hipoparts.com
